We’re testing the CRS112-8P-4S-IN. We suddenly found we can’t block MAC winbox access even block everything in IP firewall and allow nothing in mac-winbox-server. We can still access Winbox through MAC address via ether1 with config below. Mostly are done from Quick Set(router mode) with some unnecessary lines removed. The OS version is 6.44.3.
add admin-mac=XX:XX:AC:03:XX:XX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
set [ find default-name=ether3 ] speed=100Mbps
set [ find default-name=ether4 ] speed=100Mbps
set [ find default-name=ether5 ] speed=100Mbps
set [ find default-name=ether6 ] speed=100Mbps
set [ find default-name=ether7 ] speed=100Mbps
set [ find default-name=ether8 ] speed=100Mbps
set [ find default-name=sfp9 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=sfp10 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=sfp11 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
set [ find default-name=sfp12 ] advertise=10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full
add name=WAN
add name=LAN
/interface wireless security-profiles set [ find default=yes ]
add name=dhcp ranges=192.168.18.100-192.168.18.220
add address-pool=dhcp disabled=no interface=bridge name=dhcp1
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp9
add bridge=bridge comment=defconf interface=sfp10
add bridge=bridge comment=defconf interface=sfp11
add bridge=bridge comment=defconf interface=sfp12
add interface=ether1 list=WAN
add interface=bridge list=LAN
add address=192.168.18.1/24 interface=ether2 network=192.168.18.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether1
add address=192.168.18.0/24 gateway=192.168.18.1 netmask=24
#!!!!!!!!!!!!!!!!!!!!!!!!!Block everything!!!!!!!!!!!!!!!!!!!!!!!!!
add action=drop chain=forward
add action=drop chain=output
add action=drop chain=input
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
