I am trying to configure some basic VLAN separation on several CRS112 switches and I am running into a problem where the same (or a very similar) configuration behaves differently on different physical switches. I've been trying to understand and solve this issue for a few days now and I am out of ideas. The situation:
CRS112 Switch A: a switch fresh out of the box configured with 3 VLANs:
# RouterOS 7.21.5
# model = CRS112-8P-4S
add admin-mac="some MAC" auto-mac=no comment=defconf name=bridgeLocal
/interface vlan
add interface=bridgeLocal name=MGMT vlan-id=130
add interface=bridgeLocal name=VLAN10temp vlan-id=10
/interface ethernet switch
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports=ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,sfp9,sfp10,sfp11,sfp12
/port
set 0 name=serial0
add bridge=bridgeLocal comment=defconf interface=ether1
add bridge=bridgeLocal comment=defconf interface=ether2
add bridge=bridgeLocal comment=defconf interface=ether3
add bridge=bridgeLocal comment=defconf interface=ether4
add bridge=bridgeLocal comment=defconf interface=ether5
add bridge=bridgeLocal comment=defconf interface=ether6
add bridge=bridgeLocal comment=defconf interface=ether7
add bridge=bridgeLocal comment=defconf interface=ether8
add bridge=bridgeLocal comment=defconf interface=sfp9
add bridge=bridgeLocal comment=defconf interface=sfp10
add bridge=bridgeLocal comment=defconf interface=sfp11
add bridge=bridgeLocal comment=defconf interface=sfp12
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether7,ether8 vlan-id=99
add tagged-ports=switch1-cpu,ether7,ether8 vlan-id=130
add tagged-ports=switch1-cpu,ether7,ether8 vlan-id=10
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=99 ports=ether1,ether2
add customer-vid=0 new-customer-vid=130 ports=ether3,ether4,ether5,sfp9,sfp10,sfp11,sfp12
add customer-vid=0 new-customer-vid=10 ports=ether6
add ports=ether1,ether2,ether7,ether8 vlan-id=99
add ports=switch1-cpu,ether3,ether4,ether5,ether7,ether8,sfp10,sfp9,sfp12,sfp11 vlan-id=130
add ports=switch1-cpu,ether6,ether7,ether8 vlan-id=10
add address=192.168.130.254/24 interface=MGMT network=192.168.130.0
add address=10.11.10.222/24 disabled=yes interface=VLAN10temp network=10.11.10.0
/ip dhcp-client
add comment=defconf interface=bridgeLocal
/ip hotspot profile
/snmp
set enabled=yes
/system note
set show-at-login=no
/system routerboard settings
set enter-setup-on=delete-key
CRS112 Switch B: configuration very similar to Switch A. Some differences like having only one trunk port instead of two, etc.:
# RouterOS 7.21.5
add admin-mac="some other MAC" auto-mac=no comment=defconf name=bridge
/interface vlan
add interface=bridge name=MGMT vlan-id=130
add interface=bridge name=VLAN10tmp vlan-id=10
add comment="This is used to avoid the \"martian\" packet spam on the NUCs." name=WINBOX_DISCOVERY
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp9
add bridge=bridge comment=defconf interface=sfp10
add bridge=bridge comment=defconf interface=sfp11
add bridge=bridge comment=defconf interface=sfp12
add tagged-ports=ether8 vlan-id=99
add tagged-ports=switch1-cpu,ether8 vlan-id=130
add tagged-ports=switch1-cpu,ether8 vlan-id=10
add customer-vid=0 new-customer-vid=130 ports=ether3,ether4,ether5,ether6,sfp9,sfp10,sfp11,sfp12
add customer-vid=0 new-customer-vid=10 ports=ether7
set 6 custom-drop-counter-includes=ingress-vlan-filtered
add ports=ether1,ether2,ether8 vlan-id=99
add ports=switch1-cpu,ether3,ether4,ether5,ether6,ether8,sfp10,sfp9,sfp12,sfp11 vlan-id=130
add ports=switch1-cpu,ether7,ether8 vlan-id=10
add interface=MGMT list=WINBOX_DISCOVERY
add address=10.11.10.222/24 interface=VLAN10tmp network=10.11.10.0
/system identity
set name=MikroTik-CRS112-D7C0
I then try to connect a "dumb" VLAN unaware Mikrotik CRS112 switch C to the port 6 on Switch A or port 7 on Switch B. When I connect it to Switch A, everything works fine. I can ping the management interface of Switch C and I can also communicate with all devices connected to Switch C. These devices will land in the VLAN 10, as expected. However, when I connect the Switch C to Switch B instead, I get no communication. I cannot ping the Switch C management interface, nor can I ping any devices connected to that switch. I can at least ping the VLAN10tmp interface configured on the Switch B from my VLAN10 device that is located behind the trunk, so at least a part of it works. The config of Switch C:
# RouterOS 7.21.5
add admin-mac="some other other MAC" auto-mac=no comment=defconf name=bridge
add name=WAN
add name=LAN
add interface=ether1 list=WAN
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=sfp9 list=LAN
add interface=sfp10 list=LAN
add interface=sfp11 list=LAN
add interface=sfp12 list=LAN
add address=10.11.10.10/24 comment=defconf interface=ether2 network=10.11.10.0
/system identity
set name=MikroTik-CRS112-E731
So the issue is that I simply cannot connect Switch C to Switch B's untagged port ether7 and I am failing to notice any difference in configuration relative to Switch A, where everything works as I would expect.
What am I missing here?
