CRS112 Total Current Limit
I read in the specs that the total current flow is 2.8A@24V and 1.4A@48-57V. This limit is because the included power supply can’t provide more amps, or is hardware limit? If i Connect an 10Amp 24v power supply, will this make the total current limit value higher? I want to connect 4 PoE devices that works only with 1 Amp and other 4 with 0.5 Amp consumption
