I configured VLANs as described here: https://wiki.mikrotik.com/wiki/Manual:CRS1xx/2xx_series_switches_examples
It is very simple config:
- ether2,3 VLAN11 subnet 192.168.11.0/24
- ether3,4 VLAN22 subnet 192.168.22.0/24
Looks like everything is working fine I got correct IP from DHCP and connection is OK but performance is quite bad.
When I tried copy file from one PC to another on default configuration speed was around 110 MB/s and CPU was fine after I added VLANs and connected 2 PC to the same VLAN (ether2,3) and tried copy same file I got 40 MB/s and CPU utilization was 100%
As both PC are in same VLAN / subnet why are packet processed by CPU ? I can understand when I start copy between VLANs then packets should be processed by CPU as routing is required.
Could you please check my configuration. May be I did something wrong.
Really appreciate you help …
Link to my notes from learning and doing configuration: https://drive.google.com/open?id=1qpmXQ0sg3XaoUyTLylxXkwUeP0td4vP_
My configuration:
add name=bridge protocol-mode=none
/interface vlan
add comment=familly1 interface=bridge name=VLAN11 vlan-id=11
add comment=familly2 interface=bridge name=VLAN22 vlan-id=22
/interface ethernet switch
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports=ether1,ether2,ether3,ether4
add name=familly1 ranges=192.168.11.100-192.168.11.200
add name=familly2 ranges=192.168.22.100-192.168.22.200
add address-pool=familly1 disabled=no interface=VLAN11 name=familly1
add address-pool=familly2 disabled=no interface=VLAN22 name=familly2
add bridge=bridge interface=ether2
add bridge=bridge interface=ether3
add bridge=bridge interface=ether4
add bridge=bridge interface=ether5
/interface ethernet switch egress-vlan-tag
add tagged-ports=switch1-cpu vlan-id=11
add tagged-ports=switch1-cpu vlan-id=12
/interface ethernet switch ingress-vlan-translation
add comment=familly1 customer-vid=0 new-customer-vid=11 ports=ether2,ether3
add comment=familly2 customer-vid=0 new-customer-vid=22 ports=ether4,ether5
add comment=familly1 ports=switch1-cpu,ether2,ether3 vlan-id=11
add comment=familly2 ports=switch1-cpu,ether4,ether5 vlan-id=22
add address=192.168.99.1/24 comment=WAN interface=ether1 network=192.168.99.0
add address=192.168.11.1/24 comment=familly1 interface=VLAN11 network=192.168.11.0
add address=192.168.22.1/24 comment=familly2 interface=VLAN22 network=192.168.22.0
add address=192.168.11.0/24 dns-server=8.8.8.8 gateway=192.168.11.1
add address=192.168.12.0/24 dns-server=8.8.8.8 gateway=192.168.22.1
Thanks and regards,
MK
