I have CRS125-24G-1S-2HnD with following config:
- eth1 - Internet port (no master port)
- eth22 - server port (no master port)
- eth1+eth22 together in one internet-bridge
- all other ports in local-bridge with master port eth2
- 2 external ip addresses assigned to internet-bridge
In this configuration second external IP address does not work at all (not ping and port forwarding does not work). If I disable Allow Fast Path in Bridge settings then everything works. Also If I remove eth2 from the internet-bridge and assign eth1 as master port to eth2 then everything works even with enabled Allow Fast Path.
Why it is happening?
Best Regards,
Dmitry
