CRS125-24G-1S-2HND-IN - antennas are detachable?
Hi.
I couldnt find info about this - are antennas in CRS125-24G-1S-2HND-IN are detachable? I.eg. for external antenna.
yes - MMCX connector
Ok but pigtails are internal part of anennas or there are rpsma’s at back of of case?
pigtails are internal part of antennas?
Yes
You need this pigtail http://routerboard.com/ACMMCXRPSMA
to connect your own antenna
Ok, thanks.
or this on http://routerboard.com/ACMMCX and a N to PRSMA adapter
they fit into the holes in the back of the case.
see: http://forum.mikrotik.com/t/wish-rb2011uias-2hnd-rm/75105/1
