I went looking at vlan support on the unit and using the information located http://wiki.mikrotik.com/wiki/Manual:CRS_examples
under intervlan routing section then made use of the mikrotik bandwith test and its maxing out at a wooping 25Mbps.
is their something wrong with the crs125 firmware ?
Hi! I have same problem.
In one bridge I reached near 700 Mbps between 2 laptops with gigabit NIC by BTest with UDP.
But when I move one laptop to other VLAN (VLAN routed by this CRS) I found that speed is only near 15-20 Mbps, it’s very low speed.
But if I disable 1Gbit modes (half- and full-duplex) on interfaces and link only 100 Mbps full-duplex – I can reach all link’s throughput. I then try to enable flow-control on 1 Gbps mode, but it not helps.
it does not matter packet size. everything that is tossed at it has roughly the same rate though-put.
from 512 byte packets to whatever one would pick. It just happened the last thing i had open on the unit was the packet size above. I will be looking at dropping the nic speeds to 100 and see if the full 100mb speeds are obtained.
Did you configure vlans in the switch menu or through the regular routeros interface? Vlans configured through interfaces> vlan will be handled by the cpu not the switch chip.
Refer to the manuals for swos when configuring the vlans, the setup is exactly the same.
Routing between vlans will still be done by thr cpu if you configure the crs for that, which it really isn’t meant to do real well. That mips cpu can only handle 300 mbps tcp or so. Although you could try enabling hardware fast-path. Don’t know if it would do ananything for you.
Crs is meant to be a switch with limited l3 capabilities. IMHO it should be marketed as a smart switch with limited l3 capabilities because it is by no means a full l3 switch. It is lacking wire-speed inter-vlan routing.
