I cant seem to find any info or bottom side pictures of crs125-24g-1s-2hnd-in … so I ask here … can it be wall mounted in a same way as rb2011-uas-2hndin or rb951g-2hnd - just hung on 2 screws ?
TNX.
JF.
TNX.
JF.
Just looked at the bottom of mine… no holes.
Damn … will have to figure out something else to have it wall mounted for a customer … thanks for your info.
JF.
NP… you could always get the rackmount version and a vertical mounted rack… but then you loose wireless.
Thank you for the suggestion, we will consider this for a future revision.
Hi, it’s been a few months now, are the CRS125-24G-1S-2HnD-IN wall mountable now?
