CRS125-24G-1S Conslole
Hi there,
Can you please advise how the console on the Core Router Switch works ?
As I have tried different cables but still not getting output, if I press enter it prints one unknown character.
I have tried original cisco console cable, straight and rollover cable with juniper RJ45 to DB-9 adapter.
I am using usb to RS232 adapter, but console connection to a juniper router works just fine.
Thank you.
You’ll have to configure your serial port for baud 115200, 8N1.
Thank you Sparkling , this worked .
