CRS125-24G-1S - inter-vlan routing problem
Hi!
I have troubles implementing the simpliest scheme from the CRS Examples wiki.
Interfaces ether1-ether23 are slaves to ether24.
VLAN interfaces:
> /interface vlan print
Flags: X - disabled, R - running, S - slave
 #    NAME        MTU ARP        VLAN-ID INTERFACE
 0 R  vlan1        1500 enabled          1 ether24
 1 R  vlan10        1500 enabled         10 ether24
VLAN memberships:
> /interface ethernet switch vlan print
 #   VLAN-ID PORTS                                                           SVL LEARN FLOOD INGRESS-MIRROR QOS-GROUP
 0 D    4095 switch1-cpu                                                     no  no    no    no             none
 1         1 ether3                                                          no  yes   no    no             none
             ether4
             ether9
             ether19
             ether20
             ether21
             ether22
             ether23
             ether24
             switch1-cpu
 2        10 ether2                                                          no  yes   no    no             none
             ether5
             ether6
             ether7
             ether8
             ether11
             ether19
             switch1-cpu
VLAN tagging:
> /interface ethernet switch egress-vlan-tag print
 #   VLAN-ID TAGGED-PORTS
 0 D    4095
 1         1 switch1-cpu
 2        10 switch1-cpu
Ingress translation:
> /interface ethernet switch ingress-vlan-translation print
 0   ports=ether3,ether4,ether9,ether20,ether21,ether22,ether23,ether24
     service-vlan-format=any customer-vlan-format=any new-customer-vid=1
     pcp-propagation=no sa-learning=yes
 1   ports=ether2,ether5,ether6,ether7,ether8,ether11
     service-vlan-format=any customer-vlan-format=any new-customer-vid=10
 2 D ports="" service-vlan-format=any customer-vlan-format=any new-customer-vid=4095
     pcp-propagation=no sa-learning=no
IP addresses:
   > /ip address print
 #   ADDRESS            NETWORK         INTERFACE
 0   xxx.xxx.xxx.190/28 xxx.xxx.xxx.176 vlan1
 1   10.109.73.190/24   10.109.73.0     vlan10
So, the problem is I cannot access from host in VLAN1 to host in VLAN10
Host in VLAN1 has static route to network 10.109.73.0/24 via IP address of vlan1 interface
10.109.73.0     xxx.xxx.xxx.190 255.255.255.0   UG    0      0        0 vmbr0
But hosts in both vlans are accessible from the Mikrotik.
> ping 10.109.73.87
HOST                                     SIZE TTL TIME  STATUS
10.109.73.87                               56 255 1ms
10.109.73.87                               56 255 0ms
> ping xxx.xxx.xxx.179
xxx.xxx.xxx.179                            56  64 0ms
I also used packet sniffer to find out that packets are received on vlan1 interface, but seem to be “stuck” inside Mikrotik — vlan10 interface has no traffic at the time of tests.
Please help me find out what I am missing in configuration.
Thanks!
Solved it.
IP forwarding seems to be disabled on CRS by default, so I just had to turn it on.
