CRS125-24G-1S Minimal Configuration
Can somebody provide the MINIMAL configuration so that this device just acts like a 24 port switch, but has an IP that can be used to access the device from anywhere. What I would suspect is a /ip address and /ip route would be it. However, the device does not seem to act like a switch as default with no configuration.
Once you add master-port to all but one of the interfaces it seems to behave like a switch, however I thought that now means that all packets must flow through the CPU interface and that likely means you are giving up wire speed with the processing power these devices have.
For all the other models: All the ports are switched.
http://i.mt.lv/routerboard/files/CRS-24port-series-qg.pdf
btw switch means that data is not procesed in the cpu.
