CRS125-24G-1S open ports trouble Newbie asks 4 help.
Hi guys. Sorry for some grammar mistakes)
I need to open ports 10050 and 161 on my CRS for zabbix. i`ve spend 2 days for that so decide to ask you bout any advice or help.
in firewall and NAT rules was created to accept theese connections but when i try to connect from remote zabbix server via telnet xxx.xxx.xxx.xxx 161 it tells me
telnet: Unable to connect to remote host: Connection refused
thats my first experience with mikrotik. if you need some kind of info - ask and ill give you.
Thanks in advance)
So you’ve created port forwards for ports 10050 and 161?
What port are you trying to telnet in on? 23?
May be why you can’t.
i was trying to telnet 161 port.
Telnet uses TCP where SNMP on port 161 is UDP. You will not be able to telnet to 161.
use something like snmpwalk to test SNMP
