CRS125-24G-1S-RM bricked
two days ago about 9 PM people from the office reported they couldn’t connect to our network through VPN. After a diagnosis (remote and local one hour later):
  • MT responds to ping (locally and over the internet)
  • DHCP server works perfectly
  • LCD panel responds
  • MT allows connection through VPN (MT only forwards a port to OpenVPN server on our network)…
  • …but doesn’t allow access anyone to access our resources (shared drives etc.)
  • clients on local network can ping outside addresses…
  • …but aren’t allowed to browse the web
  • MT isn’t accessible through WinBox (outside address, inside address or through configured eth24 management port with separate network)
RouterOS: 6.39.1
Can I do something to:
  1. Download the current configuration from it (there were some modifications since I made the last .backup)
  2. Make it work again :slight_smile:
    One thing I was doing the same day was reconfiguring some port forwarding to local machines through WinBox.
Best regards!
It sounds as though your device has been compromised. If you connect can you get into Winbox through MAC address as that does not require IP connectivity?
You will only get a backup of your device if you can gain administrative access, if you can’t then reset and reconfigure ensuring good security is followed.
It worked with the MAC address, thank you!
But if it is compromised am I correct to assume, it may not be a good idea to copy the config to another device?
If you’re in it may not be compromised. For safety I’d probably make a backup anyway.
