Hi
I am a big fan of Mikrotik. I have used many mikrotik products on our network includes RB750, RB450, CCR 1036 etc. I never had problem using these products apart from some odd bugs which was fixed and since than they are running very smoothly. But the CRS125 is not upto the mark which i was expecting from Mikrotik. It makes our network very slow and the customers complained about the poor speed as we were using it as a switch. We have to unplug it from our network because it made the network very slow. Today i faces a new problem as we intended to configure it as a router but it wouldn’t boot for some reason. The message we seen is " Loading Kernel from NAND" after it goes to “loading configuration”. Nothing happen after that, we tried to unplug it and plug it again but the it doesn’t load the configuration. while the CRS125 was on that mood it cannot be accessed through winbox. We have to reset it and it did load as no configuration has been made it. We do not want to configure it as a router as it is not up to the mark which we were think like the other mikrotik products. Can anyone please tell us what is the problem with this specific product and can anyone from Mikrotik let us know if it is the big that is causing the problem and when can we expect for it is to get fixed and also the CRS manual when it will be publish? Thank you in advance.
n4yeem,
Seems that you have a problem with RouterOS v6.7 on CRS125. Write to MikroTik support to receive RouterOS v6.8rc1 for your CRS125.
