I have the CRS125-24G-1S+RM switch and I'm experiencing problems with one of the Inter-VLANs that I'm assigning start having high response times unintentionally and losing packets
Experiment with one of the VLANs this problem ID = 103
Change of port same problem
Change of ID and the same problem
this is me config
set [ find default-name=ether24 ] name=GlobaLAN
set [ find default-name=ether1 ] comment=Nodo_Santana_1_Hotel master-port=GlobaLAN
set [ find default-name=ether2 ] master-port=GlobaLAN
set [ find default-name=ether3 ] master-port=GlobaLAN
set [ find default-name=ether4 ] master-port=GlobaLAN
set [ find default-name=ether5 ] master-port=GlobaLAN
set [ find default-name=ether10 ] master-port=GlobaLAN
/ip neighbor discovery
set ether1 comment=Nodo_Santana_1_Hotel
/tool user-manager customer
set admin access=own-routers,own-users,own-profiles,own-limits,config-payment-gw
/interface ethernet switch egress-vlan-tag
add tagged-ports=GlobaLAN vlan-id=101
add tagged-ports=GlobaLAN vlan-id=102
add tagged-ports=GlobaLAN vlan-id=100
add tagged-ports=GlobaLAN vlan-id=103
add tagged-ports=GlobaLAN vlan-id=104
/interface ethernet switch ingress-vlan-translation
add new-customer-vid=101 ports=ether2
add new-customer-vid=102 ports=ether3
add new-customer-vid=100 ports=ether1
add new-customer-vid=103 ports=ether4
add new-customer-vid=104 ports=ether5
add address=192.168.88.1/8 comment="default configuration" interface=ether7
network=192.0.0.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether6
/lcd
set backlight-timeout=never
/lcd interface pages
set 1 interfaces=ether13,ether14,ether15,ether16,ether17
/system lcd
set contrast=0 enabled=no port=parallel type=24x4
/system lcd page
set time disabled=yes display-time=5s
set resources disabled=yes display-time=5s
set uptime disabled=yes display-time=5s
set packets disabled=yes display-time=5s
set bits disabled=yes display-time=5s
set version disabled=yes display-time=5s
set identity disabled=yes display-time=5s
set ether1 disabled=yes display-time=5s
set ether2 disabled=yes display-time=5s
set ether3 disabled=yes display-time=5s
set ether4 disabled=yes display-time=5s
set ether5 disabled=yes display-time=5s
set ether6 disabled=yes display-time=5s
set ether7 disabled=yes display-time=5s
set ether8 disabled=yes display-time=5s
set ether9 disabled=yes display-time=5s
set ether10 disabled=yes display-time=5s
set ether11 disabled=yes display-time=5s
set ether12 disabled=yes display-time=5s
set ether13 disabled=yes display-time=5s
set ether14 disabled=yes display-time=5s
set ether15 disabled=yes display-time=5s
set ether16 disabled=yes display-time=5s
set ether17 disabled=yes display-time=5s
set ether18 disabled=yes display-time=5s
set ether19 disabled=yes display-time=5s
set ether20 disabled=yes display-time=5s
set ether21 disabled=yes display-time=5s
set ether22 disabled=yes display-time=5s
set ether23 disabled=yes display-time=5s
set GlobaLAN disabled=yes display-time=5s
set sfp1 disabled=yes display-time=5s
/tool user-manager database
set db-path=user-manager
