Guy,
Today I have an smart switch and a RB45G .
If I by a CRS125-24G-1S-RM can I replace both for this cloud switch/router ? as I see, this peace of art is a switch and a router te same hardware, is this correct ?
heers
Guy,
heers
How much traffic do you need to nat?
It is a small office, no more then 20 estatiina connected.
Why?
To know of this routerboard can handle it.
You will not experience any problems with this router board.
The routerboarden have a very good performance.
In theory, yes, they both use the same family type of CPU only a little bit slower clock-rate (and a bit different chip specifications). But 680Mhz vs 600Mhz isn’t that much of a difference. Then again, I have heard the CRS125 is not AS FAST as say an RB2011 at everything because it’s meant to be a switch, but I don’t see a technical reason why this would be true.
In reality I believe it will work fine. I have used a CRS125 up to 100Mbit (very light config) or 50Mbit (Queues, etc.) without problems.
Final answer, should be no problem at all. ![]()
Don’t use many firewall and routing rules.
This is hard to handle for the some light cpu.
I have one and are verry satified with his performance.
I use it for nat 2 ISP to 3 networks
Thanks guys!
Cheers
