Hello folks.
Most of switches in my network are Cisco’s. I bought Mikrotik CRS to test so currently I feel totally lost.
I have to configure the switch the following way:
port 3 - access port vlan 135
port 4 - access port vlan 2952
port 5 - access port vlan 2952
port 11 and 12 - trunk ports with vlans 2950-2954, 2956-2959
port 14 and 15 - access port vlan 873
port 14 and 15 - access port vlan 100
port 22 and 23 - trunk ports with all possible vlans
port 24 - access port vlan 10
all other ports - access ports with vlan 130
Management interface on vlan 1. Ip, say 192.168.1.15/24 gw 192.168.1.1
Currently I have the following non-working config:
set [ find default-name=ether1 ] name=ether1-Master
set [ find default-name=ether2 ] master-port=ether1-Master
set [ find default-name=ether3 ] name=ether3-SNMPC
set [ find default-name=ether4 ] name=ether4-STORAGE
set [ find default-name=ether5 ] name=ether5-TELETORN
set [ find default-name=ether6 ] name=ether6-Naverh1
set [ find default-name=ether7 ] name=ether7-Nverh2
set [ find default-name=ether8 ] master-port=ether1-Master
set [ find default-name=ether9 ] master-port=ether1-Master
set [ find default-name=ether10 ] master-port=ether1-Master
set [ find default-name=ether11 ] name=ether11-Miratel1
set [ find default-name=ether12 ] name=ether12-Miratel2
set [ find default-name=ether13 ] master-port=ether1-Master
set [ find default-name=ether14 ] name=ether14-SAATURN1
set [ find default-name=ether15 ] name=ether15-SATRUN2
set [ find default-name=ether16 ] name=ether16-ULEMISTE
set [ find default-name=ether17 ] master-port=ether1-Master
set [ find default-name=ether18 ] master-port=ether1-Master
set [ find default-name=ether19 ] master-port=ether1-Master
set [ find default-name=ether20 ] master-port=ether1-Master
set [ find default-name=ether21 ] master-port=ether1-Master
set [ find default-name=ether22 ] name=ether22-Mikrotik2
set [ find default-name=ether23 ] name=ether23_Mikrotik1
set [ find default-name=ether24 ] name=ether24-Infonet
/interface vlan
add interface=ether22-Mikrotik2 l2mtu=1584 name=mgmnt use-service-tag=yes \
vlan-id=1
/interface ethernet switch egress-vlan-tag
add tagged-ports=\
ether11-Miratel1,ether12-Miratel2,ether22-Mikrotik2,ether23_Mikrotik1 \
vlan-id=2952
add tagged-ports=\
vlan-id=2953
add tagged-ports=\
vlan-id=2951
add tagged-ports=\
vlan-id=2954
add tagged-ports=ether6-Naverh1,ether7-Nverh2 vlan-id=1
add tagged-ports=\
ether6-Naverh1,ether7-Nverh2,ether22-Mikrotik2,ether23_Mikrotik1 vlan-id=\
135
add tagged-ports=ether22-Mikrotik2,ether23_Mikrotik1 vlan-id=873
add tagged-ports=ether22-Mikrotik2,ether23_Mikrotik1 vlan-id=100
add tagged-ports=switch1-cpu vlan-id=130
/interface ethernet switch ingress-vlan-translation
add customer-vid=135 ports=ether3-SNMPC
add customer-vid=2952 ports=ether4-STORAGE
add customer-vid=2952 ports=ether5-TELETORN
add customer-vid=100 ports=ether16-ULEMISTE
add customer-vid=10 ports=ether24-Infonet
add customer-vid=130 ports="ether1-Master,ether2,ether8,ether9,ether10,ether13\
,ether17,ether18,ether19,ether20,ether21"
add ports=\
vlan-id=2952
add ports="ether3-SNMPC,ether6-Naverh1,ether7-Nverh2,ether22-Mikrotik2,ether23\
_Mikrotik1" vlan-id=135
add ports=\
ether14-SAATURN1,ether15-SATRUN2,ether22-Mikrotik2,ether23_Mikrotik1 \
vlan-id=873
add ports=ether16-ULEMISTE,ether22-Mikrotik2,ether23_Mikrotik1 vlan-id=100
add ports=ether22-Mikrotik2,ether23_Mikrotik1,ether24-Infonet vlan-id=10
add ports=\
vlan-id=2951
add ports=\
vlan-id=2953
add ports=\
vlan-id=2954
add ports=ether6-Naverh1,ether7-Nverh2,switch1-cpu vlan-id=1
add ports="ether1-Master,ether2,ether8,ether9,ether10,ether13,ether17,ether18,\
ether19,ether20,ether21,switch1-cpu" vlan-id=130
add address=192.168.1.15/24 interface=mgmnt network=192.168.1.0
/system routerboard settings
set protected-routerboot=disabled
I can’t access switch via IP but I can access switch via mac form any vlan.
Please help.
