CRS125-24G-1S VLAN leak due to Dynamic created VLANs with ID above 4000
Dear All,
Can you please help with issue I have with CRS125 and simple VLAN scenario where ethernet-1 is a trunk port with vlans 1,100 and port8 should be access port for vlan 1 and port16 access port for vlan100.
Unfortunately I cannot make a port as an ACCESS port on this switch, when I mirror the traffic leaving the eth6 and eth16, i can see all the traffic from eth1 with all the tagging.
I believe this is due to dynamically created vlans I have found on the switch but I cannot delete them .
An answers for the following questions would be very appreciated :
1.Why I see these dynamically created vlans [4095,4089]on CRS and how can I get rid of them
2.How can I strip the VLAN tag as the traffic leaving the access port
(on a mikrotik router I can see vlan-mode and VLAN-HEADER [leave,strip,add if missing] options under the switching)
3.What doest the Egress VLAN mode and VLAN type do under switch ports ? As if I change it between [unmodified/untagged] I cannot see any difference and the access ports are still egressing all vlans and all tagged.
/interface ethernet switch egress-vlan-tag print
 #   VLAN-ID TAGGED-PORTS
 0 D    4095
 1 D    4089
 2         1 ether1-gateway
             switch1-cpu
 3       100 ether1-gateway
/interface ethernet switch vlan print
 #   VLAN-ID PORTS        SVL LEARN FLOOD INGRESS-MIRROR QOS-GROUP
 0 D    4095 ether23-slave-local                                                              no  no    no    no             none
             ether24
             sfp1-gateway
             switch1-cpu
 1 X     666 ether23-slave-local                                                              no  yes   yes   no             none
             ether24
 2 X     900 ether18-master        no  yes   no    no             none
             ether23-slave-local
 3 D    4089 ether1-gateway        no  yes   no    no             none
             ether2-master-local
             ether3-slave-local
             ether4-slave-local
             ether5-slave-local
             ether6-slave-local
             ether7-slave-local
             ether8-slave-local
             ether9-slave-local
             ether10-slave-local
             ether11-slave-local
             ether12-slave-local
             ether13-slave-local
             ether14-slave-local
             ether15-slave-local
             ether16-slave-local
             ether17-master
             ether18-master
             ether19-slave-local
             ether20-slave-local
             ether21-slave-local
             ether22-slave-local
             switch1-cpu
 4         1 ether1-gateway        no  yes   no    no             none
             ether8-slave-local
             switch1-cpu
 5       100 ether1-gateway        no  yes   no    no             none
             ether16-slave-local
 6         2 ether2-master-local                                                              no  yes   no    no             none
             ether4-slave-local
/interface ethernet switch ingress-vlan-translation print
 0   ports=ether8-slave-local service-vlan-format=any customer-vlan-format=any customer-vid=0 new-customer-vid=1 pcp-propagation=no sa-learning=yes
 1   ports=ether16-slave-local service-vlan-format=any customer-vlan-format=any new-customer-vid=100 pcp-propagation=no sa-learning=yes
 2 D ports=ether1-gateway,ether2-master-local,ether3-slave-local,ether4-slave-local,ether5-slave-local,ether6-slave-local,ether7-slave-local,ether8-slave-local,ether9-slave-local,ether10-slave-local,ether11-
      slave-local,ether12-slave-local,ether13-slave-local,ether14-slave-local,ether15-slave-local,ether16-slave-local,ether17-master,ether18-master,ether19-slave-local,ether20-slave-local,ether21-slave-local,
      ether22-slave-local
     service-vlan-format=any customer-vlan-format=any new-customer-vid=4089 pcp-propagation=no sa-learning=yes
 3 D ports=ether23-slave-local,ether24,sfp1-gateway service-vlan-format=any customer-vlan-format=any new-customer-vid=4095 pcp-propagation=no sa-learning=no
/interface ethernet print
Flags: X - disabled, R - running, S - slave
 #    NAME                            MTU MAC-ADDRESS       ARP        MASTER-PORT                          SWITCH
 0 R  ;;; Mikrotik 260G - port 2
      ether1-gateway                 1500 4C:5E:0C:97:A2:57 enabled    none                                 switch1
 1 RS ;;; NZXT - USB 2
      ether2-master-local            1500 4C:5E:0C:97:A2:58 enabled    ether1-gateway                       switch1
 2 XS ether3-slave-local             1500 4C:5E:0C:97:A2:59 enabled    ether1-gateway                       switch1
 3 XS ;;; ADVA_Management
      ether4-slave-local             1500 4C:5E:0C:97:A2:5A enabled    ether1-gateway                       switch1
 4 XS ether5-slave-local             1500 4C:5E:0C:97:A2:5B enabled    ether1-gateway                       switch1
 5 XS ether6-slave-local             1500 4C:5E:0C:97:A2:5C enabled    ether1-gateway                       switch1
 6 XS ;;; Mikrotik 751G - port 1
      ether7-slave-local             1500 4C:5E:0C:97:A2:5D enabled    ether1-gateway                       switch1
 7 XS ;;; Mikrotik 751G - port 2
      ether8-slave-local             1500 4C:5E:0C:97:A2:5E enabled    ether1-gateway                       switch1
 8 XS ;;; SRX_2 [fe-0/0/0]
      ether9-slave-local             1500 4C:5E:0C:97:A2:5F enabled    ether1-gateway                       switch1
 9 XS ;;; SRX_1 [fe-0/0/0]
      ether10-slave-local            1500 4C:5E:0C:97:A2:60 enabled    ether1-gateway                       switch1
10 XS ;;; SRX_2 [fe-0/0/1]
      ether11-slave-local            1500 4C:5E:0C:97:A2:61 enabled    ether1-gateway                       switch1
11 XS ;;; SRX_1 [fe-0/0/1]
      ether12-slave-local            1500 4C:5E:0C:97:A2:62 enabled    ether1-gateway                       switch1
12 XS ;;; SRX_2 [fe-0/0/2]
      ether13-slave-local            1500 4C:5E:0C:97:A2:63 enabled    ether1-gateway                       switch1
13 XS ;;; SRX_1 [fe-0/0/2]
      ether14-slave-local            1500 4C:5E:0C:97:A2:64 enabled    ether1-gateway                       switch1
14 XS ;;; SRX_2 [fe-0/0/3]
      ether15-slave-local            1500 4C:5E:0C:97:A2:65 enabled    ether1-gateway                       switch1
15 XS ;;; SRX_1 [fe-0/0/3]
      ether16-slave-local            1500 4C:5E:0C:97:A2:66 enabled    ether1-gateway                       switch1
16 XS ;;; ADVA-port2
      ether17-master                 1500 4C:5E:0C:97:A2:67 enabled    ether1-gateway                       switch1
17 XS ;;; ADVA-port1 - NETWORK_PORT
      ether18-master                 1500 4C:5E:0C:97:A2:68 enabled    ether1-gateway                       switch1
18 XS ether19-slave-local            1500 4C:5E:0C:97:A2:69 enabled    ether1-gateway                       switch1
19 XS ether20-slave-local            1500 4C:5E:0C:97:A2:6A enabled    ether1-gateway                       switch1
20 XS ether21-slave-local            1500 4C:5E:0C:97:A2:6B enabled    ether1-gateway                       switch1
21 XS ether22-slave-local            1500 4C:5E:0C:97:A2:6C enabled    ether1-gateway                       switch1
22 R  ;;; NZXT - USB 1 [captures]
      ether23-slave-local            1500 4C:5E:0C:97:A2:6D enabled    none                                 switch1
23 X  ether24                        1500 4C:5E:0C:97:A2:6E enabled    none                                 switch1
24 X  sfp1-gateway                   1500 4C:5E:0C:97:A2:6F enabled    none                                 switch1
I was trying to follow the simple port-based vlans scenario from the wiki but still cannot achieve vlan isolation and a basic access port functionality.
I have disabled majority of the ports for testing and assign them to a single master port but still cannot remove the dynamic vlans.
I don’t usually struggle with such a simple task as configuring vlan trunk and access port but on CRS this is very confusion.
Thank you very much in advance.
The switch also behaves differently when gets rebooted, is there any configuration applied only after a reboot ?
I have also managed to remove the vlans above 4000 ( by factory default and applying the same configuration ) .. which should not be the case ..
But the switch still leaks like a hub, completely ignoring the vlan configuration.
And how is Q-in-Q working on this device ? I have of course followed the examples on wiki ,but the switch doesn’t seem to be pushing the S-tag on the frames..
I have also tried the Egress Vlan translation and translate anything leaving with a Service VID but looking at packet capture leaving the interface nothing was being tagged.
Am I missing something fundamental ?
Thank you
I subscribe to the issue
