CRS125-24G-1S
I work for a WISP, and we use the CRS125s as access switches. Each port is its own vlan. I noticed that if you do a tcpdump on an access interface you will see some broadcast traffic like hello messages and CDP and other stuff. On a TP-Link switch they have this check box that says discard unknown broadcast. If you apply it then the broadcast traffic disappears. Is there a specific way of configuring the vlans on the CRS125 or any other method that eliminates the broadcast traffic on customer vlans.
Thank you.
Check out (and disable) the IP Neighbor Discovery settings.
