There is a problem after router reset without default settings.
In terminal in winbox or ssh or telnet I have only this:
MikroTik RouterOS 6.35 (c) 1999-2016 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
and no command line.
Restore to previus settings havan’t any result.
