Hi all,
I recently acquired a CRS125 to replace my RB2011 and I’ve been configuring it, but I’m running into very slow performance between VLAN’s. I’ve been testing a with the MikroTik bandwidth tool, and it’s odd that receiving traffic is extremely slow 1700Kb/sec, while sending is possible at 70Mb/sec.
I know that this device isn’t really fast when traffic has to pass the CPU. But when running the tests, the CPU load isn’t higher than 10%. So I’m guessing I made some dumb error.. But where?
Here is a stripped down export of the Device.
# apr/03/2015 13:32:51 by RouterOS 6.27
set [ find default-name=ether2 ] master-port=ether1
set [ find default-name=ether3 ] master-port=ether1
set [ find default-name=ether4 ] master-port=ether1
set [ find default-name=ether5 ] master-port=ether1
set [ find default-name=ether6 ] master-port=ether1
set [ find default-name=ether7 ] master-port=ether1
set [ find default-name=ether8 ] master-port=ether1
set [ find default-name=ether9 ] master-port=ether1
set [ find default-name=ether10 ] master-port=ether1
set [ find default-name=ether11 ] master-port=ether1
set [ find default-name=ether12 ] master-port=ether1
set [ find default-name=ether13 ] master-port=ether1
set [ find default-name=ether14 ] master-port=ether1
set [ find default-name=ether15 ] master-port=ether1
set [ find default-name=ether16 ] master-port=ether1
set [ find default-name=ether17 ] master-port=ether1
set [ find default-name=ether18 ] master-port=ether1
set [ find default-name=ether19 ] master-port=ether1
set [ find default-name=ether20 ] master-port=ether1
set [ find default-name=ether21 ] master-port=ether1
set [ find default-name=ether22 ] master-port=ether1
set [ find default-name=ether23 ] master-port=ether1
set [ find default-name=sfp1 ] master-port=ether1
/interface vlan
add interface=ether1 l2mtu=1584 name=vlan6 vlan-id=6
add interface=ether1 l2mtu=1584 name=vlan10 vlan-id=10
add interface=ether1 l2mtu=1584 name=vlan11 vlan-id=11
add interface=ether1 l2mtu=1584 name=vlan12 vlan-id=12
add interface=ether1 l2mtu=1584 name=vlan15 vlan-id=15
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan6 name=pppoe-xxx password=xxx user=xxx
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether1,ether2,ether3,switch1-cpu vlan-id=10
add tagged-ports=ether1,ether2,ether3,switch1-cpu vlan-id=11
add tagged-ports=ether1,ether2,ether3,switch1-cpu vlan-id=12
add tagged-ports=ether1,ether2,switch1-cpu vlan-id=6
add tagged-ports=ether3,switch1-cpu vlan-id=15
/interface ethernet switch ingress-vlan-translation
add new-customer-vid=11 ports=ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,ether15,ether16
add new-customer-vid=12 ports=ether17,ether18,ether19,ether20,ether21,ether22
add address=172.16.1.1/28 interface=ether1 network=172.16.1.0
add address=172.16.10.1/24 interface=vlan10 network=172.16.10.0
add address=172.16.11.1/24 interface=vlan11 network=172.16.11.0
add address=172.16.12.1/24 interface=vlan12 network=172.16.12.0
add address=172.16.15.1/24 interface=vlan15 network=172.16.15.0
add chain=forward connection-state=established
add chain=forward connection-state=related
add action=reject chain=input connection-state=new in-interface=pppoe-xxx
add action=masquerade chain=srcnat out-interface=pppoe-xxx src-address=172.16.0.0/12 to-addresses=0.0.0.0
