CRS125: switch manual ? Switch hosts MAC addresses ?
CRS125-24G-1S show switch chip type QCA-8513L. Command “interface ethernet switch” have a lot of new possibilities (see below), but http://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features did not discover plenty of them. I found only http://wiki.mikrotik.com/wiki/Manual:CRS_examples, which is only thin snippet.
I miss here “interface ethernet switch host print” command. Looks like “interface ethernet switch unicast-fdb print” provide same info in different format. Is the “unicast-fdb” full list of mac-addresses which switch knows about ?
Thanks in advance
MartinT
[admin@CRS125] > interface ethernet switch print
                                                     type: QCA-8513L
                                              bridge-type: service-vlan-bridge
                      drop-if-no-vlan-assignment-on-ports:
  drop-if-invalid-or-src-port-not-member-of-vlan-on-ports:
                                 invalid-vlan-lookup-mode: ivl
                                     forward-invalid-vlan: yes
                          use-svid-in-one2one-vlan-lookup: no
                          use-cvid-in-one2one-vlan-lookup: yes
                                      mac-level-isolation: no
                                     vlan-level-isolation: no
                               ipv4-multicast-lookup-mode: dst-mac-and-vid-always
                         override-existing-when-ufdb-full: no
                                      unicast-fdb-timeout: 5m
                                   ingress-mirror0-enable: yes
                                     ingress-mirror0-port: switch1-cpu
                                   ingress-mirror0-format: modified
                                   ingress-mirror1-enable: yes
                                     ingress-mirror1-port: switch1-cpu
                                   ingress-mirror1-format: modified
                                     ingress-mirror-ratio: 1/1
                                    egress-mirror0-enable: yes
                                      egress-mirror0-port: switch1-cpu
                                    egress-mirror0-format: modified
                                    egress-mirror1-enable: yes
                                    egress-mirror1-format: modified
                                      egress-mirror-ratio: 1/1
                                    egress-sampling-ratio: 1/1
                                                 fdb-uses: mirror0
                                                vlan-uses: mirror0
                        mirror-egress-if-ingress-mirrored: no
                                 mirror-tx-on-mirror-port: no
                             mirrored-packet-qos-priority: 0
                          mirrored-packet-drop-precedence: green
                           bypass-vlan-ingress-filter-for:
                      bypass-l2-security-check-filter-for:
[admin@CRS125] > interface ethernet switch  ?
.. -- go up to ethernet
dscp-qos-map --
dscp-to-dscp --
edit --
egress-vlan-tag --
egress-vlan-translation --
export -- Print or save an export script that can be used to restore configuration
get -- Gets value of item's property
ingress-vlan-translation --
mac-based-vlan --
multicast-fdb --
one2one-vlan-switching --
port --
port-isolation --
port-leakage --
print -- Print values of item properties
protocol-based-vlan --
qos-group --
reserved-fdb --
reset-counters --
set -- Change item properties
shaper --
stats --
unicast-fdb --
vlan --
