CRS125: VLAN and HW Offload
Hi there.
Need some help on CRS with VLAN and HW-Offload.
I got a CRS125-24G-1S as main switch/router at home.
Port 1 is connected to ISP.
Port 2-24 are for inhouse network and added to bridge1 (192.168.0.0/24).
On Port 3 there’s a hAP ac2 (Wifi-AP). Ether1 goes to CRS.
On Port 8 there’s a hAP ac lite (Wifi-AP). Ether1 goes to CRS.
Now i’ve created 2.4 and 5GHz guest wlan interfaces (virtual) on both hAPs and i’m using VLAN-Filtering on bridge1 to handle it.
add name=bridge1 vlan-filtering=yes
/interface vlan
add interface=bridge1 name=vlan20 vlan-id=20
/interface wireless
add disabled=no mac-address=xx master-interface=wlan1 name=wlan1-vlan20 security-profile=profile-guest ssid=xx vlan-id=20 vlan-mode=use-tag
add disabled=no mac-address=xx master-interface=wlan2 name=wlan2-vlan20 security-profile=profile-guest ssid=xx vlan-id=20 vlan-mode=use-tag
add bridge=bridge1 interface=vlan20 pvid=20
add bridge=bridge1 interface=wlan1-vlan20 pvid=20
add bridge=bridge1 interface=wlan2-vlan20 pvid=20
/interface bridge vlan
add bridge=bridge1 tagged=bridge1,ether1,vlan20,wlan1-vlan20,wlan2-vlan20 vlan-ids=20
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=bridge1
add dhcp-options=hostname,clientid disabled=no interface=vlan20
I’m now getting untagged and tagged traffic on Port 3 and 8 of CRS.
To handle it on the CRS i’ve also created a vlan interface on bridge1 and enabled VLAN-Filtering.
/interface vlan
add bridge=bridge1 tagged=bridge1,vlan20,ether3,ether8 vlan-ids=20
add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1 netmask=24
add address=192.168.10.0/24 dns-server=192.168.10.1 gateway=192.168.10.1 netmask=24
add add-arp=yes address-pool=pool authoritative=after-2sec-delay disabled=no interface=bridge1 lease-time=2d name=dhcp
add add-arp=yes address-pool=pool-vlan20 authoritative=after-2sec-delay disabled=no interface=vlan20 lease-time=1d name=dhcp-vlan20
It’s working like expected but enabling VLAN-Filtering breaks HW-Offloading on the CRS.
How’d you handle it without breaking HW-Offloading?
Edit: Got it working by creating an additional bridge “bridge-vlan” with filtering enabled, moved vlan interface “vlan20” from bridge1 to bridge-vlan, created vlan interfaces ether3-vlan20 and ether8-vlan20, added everything to bridge-vlan and changed tagging to
add bridge=bridge-vlan tagged=bridge-vlan,vlan20,ether3-vlan20,ether8-vlan20 vlan-ids=20
On bridge1 the filtering is disabled and hw offloading working.
