i have a strange behavior with a CRS125-15-RM.
The Configuration is simple.
3 VLANs over 1 Master Port
The Master Port get his Settings from a Monowall
Also DHCP and DNS.
Everything works well.
But if i have a file Copy from a Windows Network Share on VLAN10, and i only try to open the same share via VLAN20, the Copy process on VLAN10 interrupts.
„Problem while Access…“
Actually there are only 1 Client per VLAN, so i cant be to much stress.
I would be cool, if somebody knows to fix this.
Thank you for your time
Cheers
Voodie
CONFIG:
/export compact
# jan/02/1970 00:58:56 by RouterOS 6.28rc14
set [ find default-name=ether9 ] master-port=ether2
set [ find default-name=ether10 ] master-port=ether2
set [ find default-name=ether11 ] master-port=ether2
/port
set 0 name=serial0
/interface ethernet switch egress-vlan-tag
add tagged-ports=ether2 vlan-id=10
add tagged-ports=ether2 vlan-id=20
add tagged-ports=ether2 vlan-id=30
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=10 ports=ether9 sa-learning=yes
add customer-vid=0 new-customer-vid=20 ports=ether10 sa-learning=yes
add customer-vid=0 new-customer-vid=30 ports=ether11 sa-learning=yes
add ports=ether2,ether9 vlan-id=10
add ports=ether2,ether10 vlan-id=20
add ports=ether2,ether12 vlan-id=30
add address=192.168.88.1/24 interface=ether1 network=192.168.88.0
