CRS125 - vlans and DHCP not working
Hello!
I’m having some troubles configuring my CRS125 switches.
My network is quite simple:
  • PPPoE WAN link
  • 2 VLANs
  • Ports 1-8 are part of VLAN10
  • Ports 9-16 are part of VLAN20
  • DHCP server on each VLAN
  • no VLAN tagging on ports (they are access ports)
I have everything set up according to howtos, and VLAN10 is working, but I don’t get IP from DHCP server and I can’t access LAN even if I set up static IP.
If I look at Switch->VLAN table, I see dynamic VLAN assigned to ports 9-16 and I guess that’s what causing me troubles:
 #   VLAN-ID PORTS                                           SVL LEARN FLOOD INGRESS-MIRROR QOS-GROUP
 0        20 ether9                                          no  yes   no    no             none
             ether10-m9
             ether11-m9
             ether12-m9
             ether13-m9
             ether14-m9
             ether15-m9
             ether16-m9
             switch1-cpu
3 D    4091 ether9                                          no  yes   no    no             n
             ether10-m9
             ether11-m9
             ether12-m9
             ether13-m9
             ether14-m9
             ether15-m9
             ether16-m9
             switch1-cpu
Thingy are the same in Ingress VLAN translation:
[admin@router] /interface ethernet switch ingress-vlan-translation> print
 0   ports=ether9,ether10-m9,ether11-m9,ether12-m9,ether13-m9,ether14-m9,ether15-m9,ether16-m9 service-vlan-format=untagged-or-tagged
     customer-vlan-format=untagged-or-tagged customer-vid=0 new-customer-vid=20 pcp-propagation=no sa-learning=yes
 1   ports=ether1,ether2-m1,ether3-m1,ether4-m1,ether5-m1,ether6-m1,ether7-m1,ether8-m1 service-vlan-format=untagged-or-tagged
     customer-vlan-format=untagged-or-tagged customer-vid=0 new-customer-vid=10 pcp-propagation=no sa-learning=yes
 2 D ports=ether9,ether10-m9,ether11-m9,ether12-m9,ether13-m9,ether14-m9,ether15-m9,ether16-m9 service-vlan-format=any
     customer-vlan-format=any new-customer-vid=4091 pcp-propagation=no sa-learning=yes
 3 D ports=ether17,ether18,ether19,ether20,ether21,ether22,ether23-mgmt,ether24-WAN,sfp1-gateway service-vlan-format=any
     customer-vlan-format=any new-customer-vid=4095 pcp-propagation=no sa-learning=no
As you can see, ports 9-16 are in VLAN20 and also in dynamic VLAN 4091. Why is that and why is that dynamic vlan there?
How can I remove it? IF I try to delete it, it says I can’t delete it since it’d dynamic:
I’m guessing packages come from the LAN and go to dynamic VLAN instead of VLAN20, hence DHCP doesn’t see the request and can’t assign IP.
Ideas?
Thanks for help, Matej
As far as I can see, when I plug in my PC to port 9-16, PC sends a DHCP request, router answers but then there is no reply.
17:30:56 dhcp,debug,packet DHCP: DHCP-Bralci received discover with id 1387401109 from 0.0.0.0
17:30:56 dhcp,debug,packet DHCP:     ciaddr = 0.0.0.0
17:30:56 dhcp,debug,packet DHCP:     chaddr = 00:04:61:17:1E:25
17:30:56 dhcp,debug,packet DHCP:     Msg-Type = discover
17:30:56 dhcp,debug,packet DHCP:     Unknown(116) = 01
17:30:56 dhcp,debug,packet DHCP:     Client-Id = 01-00-04-61-17-1E-25
17:30:56 dhcp,debug,packet DHCP:     Address-Request = 169.254.29.116
17:30:56 dhcp,debug,packet DHCP:     Host-Name = "pc-poljane"
17:30:56 dhcp,debug,packet DHCP:     Class-Id = "MSFT 5.0"
17:30:56 dhcp,debug,packet DHCP:     Parameter-List = Subnet-Mask,Domain-Name,Router,Domain-Server,NETBIOS-Name-Server,Unknown(46),Unknown(47),Unknown(31),Static-Route,M
S-Classless-Route,Vendor-Specific
17:30:56 dhcp,debug,packet DHCP:     Vendor-Specific = DC-00
17:30:57 dhcp,debug,packet DHCP: DHCP-Bralci sending offer with id 1387401109 to 192.168.31.198
17:30:57 dhcp,debug,packet DHCP:     ciaddr = 0.0.0.0
17:30:57 dhcp,debug,packet DHCP:     yiaddr = 192.168.31.198
17:30:57 dhcp,debug,packet DHCP:     siaddr = 192.168.31.1
17:30:57 dhcp,debug,packet DHCP:     chaddr = 00:04:61:17:1E:25
17:30:57 dhcp,debug,packet DHCP:     Msg-Type = offer
17:30:57 dhcp,debug,packet DHCP:     Server-Id = 192.168.31.1
17:30:57 dhcp,debug,packet DHCP:     Address-Time = 86400
17:30:57 dhcp,debug,packet DHCP:     Subnet-Mask = 255.255.255.0
17:30:57 dhcp,debug,packet DHCP:     Router = 192.168.31.1
17:30:57 dhcp,debug,packet DHCP:     Domain-Server = 192.168.31.1
DHCP config:
add address-pool=Pool-Zaposleni authoritative=yes disabled=no interface=vlan10-zaposleni lease-time=1d name=DHCP-Zaposleni
add address-pool=Pool-Bralci authoritative=yes disabled=no interface=vlan20-bralci lease-time=1d name=DHCP-Bralci
add address=192.168.30.0/24 dns-server=192.168.30.1 gateway=192.168.30.1 ntp-server=192.168.30.1
add address=192.168.31.0/24 dns-server=192.168.31.1 gateway=192.168.31.1 ntp-server=192.168.31.1
IP->Addresses:
add address=192.168.30.1/24 comment=Zaposleni interface=vlan10-zaposleni network=192.168.30.0
add address=192.168.31.1/24 comment=Bralci interface=vlan20-bralci network=192.168.31.0
Interfaces->VLAN:
/interface vlan
add interface=ether1 l2mtu=1584 name=vlan10-zaposleni vlan-id=10
add interface=ether9 l2mtu=1584 name=vlan20-bralci vlan-id=20
Switch-VLAN:
set forward-unknown-vlan=no
/interface ethernet switch egress-vlan-tag
add tagged-ports=switch1-cpu vlan-id=20
add tagged-ports=switch1-cpu vlan-id=10
add customer-vid=0 customer-vlan-format=untagged-or-tagged new-customer-vid=20 ports=\
    ether9,ether10-m9,ether11-m9,ether12-m9,ether13-m9,ether14-m9,ether15-m9,ether16-m9 sa-learning=yes service-vlan-format=untagged-or-tagged
add customer-vid=0 customer-vlan-format=untagged-or-tagged new-customer-vid=10 ports=ether1,ether2-m1,ether3-m1,ether4-m1,ether5-m1,ether6-m1,ether7-m1,ether8-m1 \
set 0 dscp-based-qos-dscp-to-dscp-mapping=no qos-scheme-precedence=pcp-based,sa-based,da-based,dscp-based,protocol-based,vlan-based,pcp-based
set 1 dscp-based-qos-dscp-to-dscp-mapping=no
set 2 dscp-based-qos-dscp-to-dscp-mapping=no
set 3 dscp-based-qos-dscp-to-dscp-mapping=no
set 4 dscp-based-qos-dscp-to-dscp-mapping=no
set 5 dscp-based-qos-dscp-to-dscp-mapping=no
set 6 dscp-based-qos-dscp-to-dscp-mapping=no
set 7 dscp-based-qos-dscp-to-dscp-mapping=no
set 8 dscp-based-qos-dscp-to-dscp-mapping=no
set 9 dscp-based-qos-dscp-to-dscp-mapping=no
set 10 dscp-based-qos-dscp-to-dscp-mapping=no
set 11 dscp-based-qos-dscp-to-dscp-mapping=no
set 12 dscp-based-qos-dscp-to-dscp-mapping=no
set 13 dscp-based-qos-dscp-to-dscp-mapping=no
set 14 dscp-based-qos-dscp-to-dscp-mapping=no
set 15 dscp-based-qos-dscp-to-dscp-mapping=no
set 16 dscp-based-qos-dscp-to-dscp-mapping=no
set 17 dscp-based-qos-dscp-to-dscp-mapping=no
set 18 dscp-based-qos-dscp-to-dscp-mapping=no
set 19 dscp-based-qos-dscp-to-dscp-mapping=no
set 20 dscp-based-qos-dscp-to-dscp-mapping=no
set 21 dscp-based-qos-dscp-to-dscp-mapping=no
set 22 dscp-based-qos-dscp-to-dscp-mapping=no
set 23 dscp-based-qos-dscp-to-dscp-mapping=no
set 24 dscp-based-qos-dscp-to-dscp-mapping=no
set 25 dscp-based-qos-dscp-to-dscp-mapping=no
add ports=ether9,ether10-m9,ether11-m9,ether12-m9,ether13-m9,ether14-m9,ether15-m9,ether16-m9,switch1-cpu vlan-id=20
add ports=ether1,ether2-m1,ether3-m1,ether4-m1,ether5-m1,ether6-m1,ether7-m1,ether8-m1,switch1-cpu vlan-id=10
add ports=ether24-WAN,switch1-cpu vlan-id=0
So, VLAN10 is working, but VLAN20 is not. Config seems the same, apart from dynamic vlans on ports 9-16.
Matej
I figured something out:
Windows 7 or Windows 8 clients can connect to VLAN20 and they get IP from DHCP.
Windows XP, network printers and one linux machine won’t work on VLAN20 no matter what.
Matej
Bump!
No one is having such problems?
Any help would be appreciated, because I don’t know how to solve this problem and I’m deploying 10 switches next week…
Matej
Multiple master-port configuration was designed as fast and simple port isolation solution, but it limits part of VLAN functionality supported by CRS switch-chip.
For advanced configurations use one master-port within CRS switch chip for all ports, configure VLANs and isolate port groups with port isolation profile configuration.
http://wiki.mikrotik.com/wiki/Manual:CRS_examples#Port-level_Isolation
Hey!
Thanks for reply and useful informations…
So if I understand what you are saying correctly I have do the following things:
  • set ether1 as master port
  • set all other ports as slave to ether1
  • set vlans and ingres vlan translations in Switch->VLAN
  • set switch port:
  • set isolation-leakage-profile-override=2 for ports 1-8 (VLAN10)
  • set isolation-leakage-profile-override=3 for ports 9-16 (VLAN10)
  • set isolation-leakage-profile-override=1 for port 24 (WAN link)
  • set isolation-leakage-profile-override=0 for switch-cpu (so all VLANS and WAN uplink can communicate with main cpu)
  • set switch port isolation
  • add each port group to it’s own port-profie
Does that sound correctly?
Follow up:
I’m having some troubles with my WAN port, because it doesn’t get the IP over DHCP until I remove it as a slave device. If I set master-port to none, I get the IP, but not if it’s set as slave to ether1.
How should I configure WAN port? As a standalone port oz part of switched ports?
What is the “uplink” from switch in my case? switch1-cpu?
Matej
What is you wan setup?
PPPoE or DHCP client?
If you receiving the PPPoE connection over a VLan then you should create that VLan on you wan interface and set the PPPoE client up on that VLan.
If the PPPoE server is not communicating over a VLan than you should have your wan’s master port set to none.
If you are using DHCP than you should have your wan’s master port set to none.
