Hi there,
Given a CRS112-8G-4S switch with one access (ether2, VLAN: 90) and one trunk port (sfp12, VLAN: 1,10,20,30,90) configured. So far so good.
My goal is to set up a VLAN interface and manage the switch (remotely) in VLAN 90.
The VLAN inteface in VLAN 90 is not working. I don’t know what’s missing.
[admin@MikroTik] > /export
# jan/02/1970 00:31:00 by RouterOS 6.49.13
# software id = 65E9-AUQV
# model = CRS112-8G-4S
# serial number = <edited>
add name=bridge1
/interface vlan
add interface=bridge1 name=mgmt vlan-id=90
/interface ethernet switch
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports=ether2,sfp12
add bridge=bridge1 interface=sfp12
/interface ethernet switch egress-vlan-tag
add tagged-ports=sfp12 vlan-id=1
add tagged-ports=sfp12 vlan-id=10
add tagged-ports=sfp12 vlan-id=20
add tagged-ports=sfp12 vlan-id=30
add tagged-ports=sfp12 vlan-id=90
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=90 ports=ether2
add ports=ether2,sfp12 vlan-id=90
add ports=sfp12 vlan-id=1
add ports=sfp12 vlan-id=10
add ports=sfp12 vlan-id=20
add ports=sfp12 vlan-id=30
add address=10.0.90.3/24 interface=mgmt network=10.0.90.0
Some evidence here…
admin@MikroTik] > ping 10.0.90.3
SEQ HOST SIZE TTL TIME STATUS
0 10.0.90.3 56 64 2ms
1 10.0.90.3 56 64 1ms
sent=2 received=2 packet-loss=0% min-rtt=1ms avg-rtt=1ms max-rtt=2ms
[admin@MikroTik] > ping 10.0.90.100
0 10.0.90.100 timeout
1 10.0.90.100 timeout
sent=2 received=0 packet-loss=100%
[admin@MikroTik] > ping 10.0.90.101
0 10.0.90.101 timeout
1 10.0.90.101 timeout
[admin@MikroTik] > ip arp print
Flags: X - disabled, I - invalid, H - DHCP, D - dynamic, P - published, C - complete
# ADDRESS MAC-ADDRESS INTERFACE
0 D 10.0.90.100 mgmt
1 D 10.0.90.101 mgmt
2 D 10.0.90.1 mgmt
I appreciate any help you can provide. Thank you!
