CRS1xx port isolation only on 1 vlan
Hello, is it possible to do port isolation on a single vlan on a CRS112? I am using the correct CRS1xx switch vlan configuration for the model as described in the wiki, and I can see how to do port isolation as well.
However I only wish to isolate the clients on the guest vlan only ( all connected to tagged ports on the switch). default forwarding is already disabled on the guest wireless interface on the AP.
previous config to do this would have been multiple bridges and split horizon, but you get reduced performance.
many thanks
