CRS212-1G-10S-1S+IN Adding a 3-Wire Fan
My CRS212 creates chronic overheating, and I have lost two SFP modems <<
I have been told (by Mikrotik Support) I can add an internal fan, powered from the JTAG pads – I see JTAG pins 7 and 8, GND and 3v3 respectively.
My fan has the common third (F-Type) wire.
I have, but two questions:
1) Where do I attach the fan’s third wire?
2) If the fan suffers a fault e.g. a short; would the fan’s direct connection to the JTAG GND, likely cause any damage?
Any help/ideas very much appreciated.
Thank you for reading my post.
The third wire is usually just a speed sensor and can be left disconnected
