CRS212 Tagged VLAN doesn´t work
I try to make tagged VLAN´s on a CRS212. But it does not work. Port SFP 10 will be the uplink and port SFP1 will be the port to a client.
So from the client side and from the uplink side tagged vlan´s arrive the switch and shoult leave the switch with the same tagged vlans.
I configured it like this, but it does not work
add name=bridge1 vlan-filtering=yes
set [ find default-name=sfp1 ] auto-negotiation=no
add bridge=bridge1 interface=sfp1
add bridge=bridge1 interface=sfp10
/interface ethernet switch egress-vlan-tag
add tagged-ports=sfp1,sfp10 vlan-id=400
add tagged-ports=sfp1,sfp10 vlan-id=200
add ports=sfp1,sfp10 vlan-id=400
add ports=sfp1,sfp10 vlan-id=200
add address=192.168.1.1/24 interface=ether1 network=192.168.1.0
Maybe someone can help me.
Regards Kangoo
Do not set vlan-filtering=yes on CRS1xx/2xx as this disables hardware switching and ignores any configuration under /interface ethernet switch …
VLAN Configuration and switching features manage differently on CRS 1xx and CRS 2xx
in this link you can find useful info
CRS1xx/2xx series switches examples
https://help.mikrotik.com/docs/pages/viewpage.action?pageId=103841836
