CRS226-24G-2S+ not usable as a router
Hi!
People, be advised, the CRS226-24G-2S+ is pretty much unusable as a router. Wasn’t able to get more than ~10 mbit/s from my ISP, wondered why, have been looking for problems for weeks (wireless etc.) … had to switch back to a $30 model RB750 to get full speed again! Wouldn’t have thought that’s possible.
Thats very odd because I have one of them routing on a 50/50 fiber that is doing quite well.
Maybe you are you bridging the LAN ports and not switching them?
Post your configuration, then we can think what is wrong.
in all honesty, if you are not able to saturate a 1gbps link, then you are doing something wrong.
It does not take much power to route.
On the other hand, it takes a lot of power to bridge, even more if you are using IP filters on that bridge.
The switched ports aren’t the problem, they can easily be saturated (gigabit).
What part of the config would you like to see? I loaded the config back to my RB450G and boom, speed was back.
BTW it only came to my mind it could be the crs because I found one or 2 threads about similar problems here in the forum. Basically the opinion was the crs isn’t suitable for more than 20 mbit/s of internet connectivity.
Please post the IP & Interface exports
OK, that’s about it:
# sep/14/2014 14:30:27 by RouterOS 6.19
# software id = 303I-LAN7
add name=loopback protocol-mode=none
set [ find default-name=ether3 ] mac-address=68:05:CA:01:E9:4F name=Closeness
set [ find default-name=ether4 ] name=LAN
set [ find default-name=ether5 ] l2mtu=9204 master-port=LAN name=\
    "Link Wohnzimmer"
set [ find default-name=ether12 ] master-port=LAN name=MacMini
set [ find default-name=ether9 ] master-port=LAN name=PowerLAN
set [ find default-name=ether1 ] mac-address=F8:1A:67:36:6B:6B name=\
    Swisscable
set [ find default-name=ether2 ] mac-address=00:0C:29:A6:6C:0C name=\
    Telefonica
set [ find default-name=ether24 ] master-port=LAN name=TimeMachine
set [ find default-name=ether11 ] master-port=LAN name="VMware ESXI"
set [ find default-name=ether13 ] master-port=LAN name=\
    "WLAN Bridge Gaestehaus"
set [ find default-name=ether7 ] master-port=LAN name=cs
set [ find default-name=ether10 ] master-port=LAN
set [ find default-name=ether14 ] master-port=LAN
set [ find default-name=ether15 ] master-port=LAN
set [ find default-name=ether16 ] master-port=LAN
set [ find default-name=ether17 ] master-port=LAN
set [ find default-name=ether18 ] master-port=LAN
set [ find default-name=ether19 ] master-port=LAN
set [ find default-name=ether20 ] master-port=LAN
set [ find default-name=ether21 ] master-port=LAN
set [ find default-name=ether22 ] master-port=LAN
set [ find default-name=ether8 ] master-port=LAN name="iMac 27"
/interface pptp-server
add name=pptp-vpn-server user=""
/interface 6to4
add comment="Hurricane Electric IPv6 Tunnel Broker" local-address=\
    xxx.xxx.60.46 mtu=1280 name=sit1 remote-address=216.66.80.98
/ip neighbor discovery
set sit1 comment="Hurricane Electric IPv6 Tunnel Broker"
set [ find default-name=ether6 ] master-port=LAN name="Airport Schreibtisch"
set [ find default-name=ether23 ] master-port=LAN name=Data
/ip ipsec proposal
set [ find default=yes ] lifetime=10m
add name=default-dhcp ranges=192.168.1.100-192.168.1.124
add address-pool=default-dhcp disabled=no interface=LAN lease-time=5m name=\
    default
/port
set 0 name=serial0
add bridge=loopback disabled=yes interface=LAN
set 0 dscp-based-qos-dscp-to-dscp-mapping=no
set 1 dscp-based-qos-dscp-to-dscp-mapping=no
set 2 dscp-based-qos-dscp-to-dscp-mapping=no
set 3 dscp-based-qos-dscp-to-dscp-mapping=no
set 4 dscp-based-qos-dscp-to-dscp-mapping=no
set 5 dscp-based-qos-dscp-to-dscp-mapping=no
set 6 dscp-based-qos-dscp-to-dscp-mapping=no
set 7 dscp-based-qos-dscp-to-dscp-mapping=no
set 8 dscp-based-qos-dscp-to-dscp-mapping=no
set 9 dscp-based-qos-dscp-to-dscp-mapping=no
set 10 dscp-based-qos-dscp-to-dscp-mapping=no
set 11 dscp-based-qos-dscp-to-dscp-mapping=no
set 12 dscp-based-qos-dscp-to-dscp-mapping=no
set 13 dscp-based-qos-dscp-to-dscp-mapping=no
set 14 dscp-based-qos-dscp-to-dscp-mapping=no
set 15 dscp-based-qos-dscp-to-dscp-mapping=no
set 16 dscp-based-qos-dscp-to-dscp-mapping=no
set 17 dscp-based-qos-dscp-to-dscp-mapping=no
set 18 dscp-based-qos-dscp-to-dscp-mapping=no
set 19 dscp-based-qos-dscp-to-dscp-mapping=no
set 20 dscp-based-qos-dscp-to-dscp-mapping=no
set 21 dscp-based-qos-dscp-to-dscp-mapping=no
set 22 dscp-based-qos-dscp-to-dscp-mapping=no
set 23 dscp-based-qos-dscp-to-dscp-mapping=no
set 24 dscp-based-qos-dscp-to-dscp-mapping=no
set 25 dscp-based-qos-dscp-to-dscp-mapping=no
set 26 dscp-based-qos-dscp-to-dscp-mapping=no
/interface pptp-server server
set authentication=mschap2 default-profile=vpn-profile enabled=yes max-mru=\
    1460 max-mtu=1460
add address=192.168.1.1/24 interface=LAN network=192.168.1.0
add address=192.168.2.2/24 interface=Telefonica network=192.168.2.0
add address=192.168.254.1/32 interface=loopback network=192.168.254.1
/ip cloud
set enabled=yes
/ip dhcp-client
add add-default-route=no dhcp-options=hostname,clientid disabled=no \
    interface=Swisscable
    interface=Closeness
/ip dhcp-server lease
add address=192.168.1.7 mac-address=00:09:34:1C:08:C4
add address=192.168.1.8 mac-address=00:08:7B:07:33:39
add address=192.168.1.9 mac-address=00:05:CD:21:F1:53
add address=192.168.1.10 always-broadcast=yes mac-address=00:1D:EC:05:79:19
add address=192.168.1.11 mac-address=00:09:34:2E:57:0F
add address=192.168.1.12 mac-address=00:09:34:1B:A7:15
add address=192.168.1.13 mac-address=00:09:34:28:11:30
add address=192.168.1.14 mac-address=00:02:72:A2:70:98
add address=192.168.1.15 mac-address=1C:C1:DE:FE:E5:33
add address=192.168.1.28 mac-address=00:15:6D:EE:A3:C2
add address=192.168.1.29 mac-address=00:15:6D:EE:A3:59
add address=192.168.1.41 mac-address=00:0C:29:C8:A1:2F
add address=192.168.1.50 mac-address=68:05:CA:01:CB:5A
add address=192.168.1.54 mac-address=00:0C:29:F4:A6:A3
add address=192.168.1.55 mac-address=00:50:56:B6:6A:08
add address=192.168.1.56 mac-address=00:0C:29:3D:A9:44
add address=192.168.1.57 mac-address=00:0C:29:FB:2A:BA
add address=192.168.1.61 mac-address=00:0C:29:F0:A9:A0
add address=192.168.1.125 mac-address=00:50:56:B6:6A:0D
add address=192.168.1.199 mac-address=44:57:52:44:81:7E
add address=192.168.1.200 mac-address=00:9C:02:5B:1C:C0
add address=192.168.1.201 mac-address=00:22:3F:F8:49:3C
add address=192.168.1.202 mac-address=00:22:3F:F8:49:34
add address=192.168.1.38 client-id=1:40:6c:8f:3b:5e:b9 mac-address=\
    40:6C:8F:3B:5E:B9 server=default
add address=192.168.1.34 always-broadcast=yes client-id=1:b8:f6:b1:10:cd:cd \
    mac-address=B8:F6:B1:10:CD:CD server=default
add address=192.168.1.39 client-id=1:0:23:df:fd:6f:53 mac-address=\
    00:23:DF:FD:6F:53 server=default
add address=192.168.1.84 always-broadcast=yes client-id=1:70:73:cb:ce:92:6d \
    mac-address=70:73:CB:CE:92:6D server=default
add address=192.168.1.37 always-broadcast=yes client-id=1:0:23:df:81:24:c6 \
    mac-address=00:23:DF:81:24:C6 server=default
add address=192.168.1.33 client-id=1:0:26:8:e1:68:20 mac-address=\
    00:26:08:E1:68:20 server=default
add address=192.168.1.82 always-broadcast=yes client-id=1:f0:cb:a1:a5:4b:eb \
    mac-address=F0:CB:A1:A5:4B:EB server=default
add address=192.168.1.36 always-broadcast=yes client-id=1:0:26:8:e8:b8:b5 \
    mac-address=00:26:08:E8:B8:B5 server=default
add address=192.168.1.81 always-broadcast=yes client-id=1:f0:cb:a1:7e:b3:3a \
    mac-address=F0:CB:A1:7E:B3:3A server=default
add address=192.168.1.87 client-id=1:90:27:e4:35:1b:26 mac-address=\
    90:27:E4:35:1B:26 server=default
add address=192.168.1.83 always-broadcast=yes client-id=1:a4:67:6:ab:b9:c2 \
    mac-address=A4:67:06:AB:B9:C2 server=default
add address=192.168.1.91 always-broadcast=yes client-id=1:4:f7:e4:4c:d0:b5 \
    mac-address=04:F7:E4:4C:D0:B5 server=default
add address=192.168.1.2 mac-address=00:0D:B9:2E:97:D9 server=default
add address=192.168.1.3 mac-address=24:65:11:77:AA:0A
add address=192.168.1.89 always-broadcast=yes client-id=1:74:e1:b6:94:ef:49 \
    mac-address=74:E1:B6:94:EF:49 server=default
add address=192.168.1.92 always-broadcast=yes client-id=1:4:f7:e4:46:8e:21 \
    mac-address=04:F7:E4:46:8E:21 server=default
add address=192.168.1.49 always-broadcast=yes client-id=1:60:45:bd:f2:c1:24 \
    mac-address=60:45:BD:F2:C1:24 server=default
add address=192.168.1.90 always-broadcast=yes client-id=1:28:e1:4c:97:7b:d3 \
    mac-address=28:E1:4C:97:7B:D3 server=default
add address=192.168.1.85 always-broadcast=yes client-id=1:b8:e8:56:85:fd:a9 \
    mac-address=B8:E8:56:85:FD:A9 server=default
add address=192.168.1.6 client-id=1:70:9e:29:37:5a:d5 mac-address=\
    70:9E:29:37:5A:D5 server=default
add address=192.168.1.47 mac-address=00:0C:29:96:67:51 server=default
add address=192.168.1.40 client-id=1:d0:50:99:2e:d1:10 mac-address=\
    D0:50:99:2E:D1:10 server=default
add address=192.168.1.48 client-id=1:d0:50:99:2e:d1:11 mac-address=\
    D0:50:99:2E:D1:11 server=default
add address=192.168.1.0/24 comment="default configuration" dns-server=\
    192.168.1.1 domain=xxx.xxx gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes servers=\
    192.168.222.1,192.168.3.20,2001:4860:4860::8844,2001:4860:4860::8888
/ip dns static
add address=192.168.1.56 name=xxx.xxx.ch
add address=192.168.1.61 name=simplebuild.xxx.xxx
add address=192.168.1.19 name=mrtg2.xxx.xxx
add address=192.168.1.127 name=bbs.xxx.xxx
add address=192.168.1.115 name=joomlaxxx.xxx.xxx.xxx
add address=192.168.1.115 name=freetemplate.xxx.xxx
add address=192.168.1.19 name=cs.xxx.xxx
add address=192.168.1.47 name=dev.projectluxury.com
add address=192.168.1.19 name=argus.xxx.xxx
add address=192.168.1.48 name=timemachine.xxx.xxx
add chain=forward comment="accept established forward" connection-state=\
    established
add chain=input comment="accept established" connection-state=established
add chain=forward comment="accept related forward" connection-state=related
add chain=input comment="accept related input" connection-state=related
add chain=input comment="default configuration" protocol=icmp
add chain=input comment="PPTP Tunnel" protocol=gre
add chain=input dst-port=1723 protocol=tcp
add chain=input protocol=icmp src-address=192.168.1.0/24
add chain=input comment="f\FCr vpn" dst-port=500 protocol=udp src-address=\
    xxx.xxx.177.42
add chain=input dst-port=500 protocol=udp src-address=xxx.xxx.60.179
add chain=input comment="SNMP Firewall" dst-port=161 protocol=udp \
    src-address=xxx.xxx.179.135
add chain=input comment="Von www.xxx.xxx alles zulassen" src-address=\
    xxx.xxx.179.135
add chain=input dst-port=8291 protocol=tcp
add chain=forward comment="Zugriff vom La Guardia auf CS" dst-address=\
    192.168.1.19 src-address=192.168.10.0/24
add chain=forward dst-address=192.168.1.19 src-address=192.168.115.0/24
add chain=input src-address=xxx.xxx.60.179
add chain=forward comment="IPSec Dino" disabled=yes dst-address=\
    192.168.1.0/24 src-address=192.168.115.0/24
add action=drop chain=forward comment="IPSec La Guardia" dst-address=\
    192.168.1.0/24 src-address=192.168.10.0/24
add action=drop chain=forward dst-address=192.168.1.0/24 src-address=\
    192.168.115.0/24
add action=drop chain=input in-interface=Swisscable
add action=drop chain=input in-interface=Telefonica
add action=drop chain=input in-interface=Closeness
/ip firewall mangle
add chain=prerouting comment="f\FCr ipsec" dst-address=192.168.10.0/24
add chain=prerouting dst-address=192.168.115.0/24
add action=mark-routing chain=prerouting comment=ipads/iphones \
    new-routing-mark=Closeness passthrough=no src-address=192.168.1.125
add action=mark-routing chain=prerouting new-routing-mark=Closeness \
    src-address=192.168.1.83
    src-address=192.168.1.85
    src-address=192.168.1.89
    src-address=192.168.1.118
add action=mark-routing chain=prerouting comment=Closeness new-routing-mark=\
    Closeness passthrough=no src-address=192.168.1.153
    passthrough=no src-address=192.168.1.154
    passthrough=no src-address=192.168.1.155
    passthrough=no src-address=192.168.1.156
    passthrough=no src-address=192.168.1.157
    passthrough=no src-address=192.168.1.158
    passthrough=no src-address=192.168.1.159
add chain=prerouting comment="f\FCr Pingtest" dst-address=xxx.xxx.179.135 \
    src-address=192.168.1.19
add chain=prerouting dst-address=xxx.xxx.60.1 src-address=192.168.1.19
add chain=prerouting dst-address=xx.xx.119.217 src-address=192.168.1.19
add action=mark-routing chain=prerouting comment=\
    "cardsharing geht \FCber Telefonica" new-routing-mark=Telefonica \
    passthrough=no src-address=192.168.1.19
add action=mark-routing chain=prerouting comment=Telefonica new-routing-mark=\
    Telefonica passthrough=no src-address=192.168.1.133
add action=mark-routing chain=prerouting new-routing-mark=Telefonica \
    passthrough=no src-address=192.168.1.134
    passthrough=no src-address=192.168.1.135
    passthrough=no src-address=192.168.1.136
    passthrough=no src-address=192.168.1.137
    passthrough=no src-address=192.168.1.138
    passthrough=no src-address=192.168.1.139
add action=mark-routing chain=prerouting comment=LoadBalance \
    new-routing-mark=Loadbalance passthrough=no src-address=192.168.1.163
add action=mark-routing chain=prerouting new-routing-mark=Loadbalance \
    passthrough=no src-address=192.168.1.164
    passthrough=no src-address=192.168.1.165
    passthrough=no src-address=192.168.1.166
    passthrough=no src-address=192.168.1.167
    passthrough=no src-address=192.168.1.168
    passthrough=no src-address=192.168.1.169
add action=mark-routing chain=prerouting comment=Swisscable new-routing-mark=\
    Swisscable passthrough=no src-address=192.168.1.183
add action=mark-routing chain=prerouting new-routing-mark=Swisscable \
    passthrough=no src-address=192.168.1.184
    passthrough=no src-address=192.168.1.185
    passthrough=no src-address=192.168.1.186
    passthrough=no src-address=192.168.1.187
    passthrough=no src-address=192.168.1.188
    passthrough=no src-address=192.168.1.189
add action=mark-routing chain=prerouting comment=Mini disabled=yes \
    new-routing-mark=Closeness passthrough=no src-address=192.168.1.37
add chain=srcnat comment="IPSec Dino" dst-address=192.168.115.0/24 \
add chain=srcnat comment="IPSec La Guardia" dst-address=192.168.10.0/24 \
add action=masquerade chain=srcnat comment="Masquerade Swisscable" \
    out-interface=Swisscable
add action=masquerade chain=srcnat comment="Masquerade Telefonica" \
    out-interface=Telefonica
add action=masquerade chain=srcnat comment="Masquerade Closeness" \
    out-interface=Closeness
add action=masquerade chain=srcnat dst-address=192.168.1.39 dst-port=22 \
    out-interface=LAN protocol=tcp src-address=192.168.1.0/24
add action=masquerade chain=srcnat dst-address=192.168.1.19 dst-port=8882 \
add action=masquerade chain=srcnat dst-address=192.168.1.10 dst-port=22 \
add action=dst-nat chain=dstnat dst-port=8882 protocol=tcp to-addresses=\
    192.168.1.19 to-ports=8882
add action=dst-nat chain=dstnat comment=bbs dst-port=80 in-interface=\
    Swisscable protocol=tcp to-addresses=192.168.1.47 to-ports=80
add action=dst-nat chain=dstnat comment=ntp dst-address=83.61.17.122 \
    dst-port=123 protocol=udp to-addresses=192.168.1.19 to-ports=123
add action=dst-nat chain=dstnat dst-port=8005 in-interface=Swisscable \
    protocol=tcp to-addresses=192.168.1.126 to-ports=80
add action=dst-nat chain=dstnat dst-port=21 in-interface=Swisscable protocol=\
    tcp to-addresses=192.168.1.115 to-ports=21
add action=dst-nat chain=dstnat dst-port=23 in-interface=Swisscable protocol=\
    tcp to-addresses=192.168.1.127 to-ports=23
add action=dst-nat chain=dstnat dst-port=25 in-interface=Swisscable protocol=\
    tcp to-addresses=192.168.1.126 to-ports=25
add action=dst-nat chain=dstnat comment=dns dst-port=53 in-interface=\
    Swisscable protocol=udp to-addresses=192.168.1.19 to-ports=53
add action=dst-nat chain=dstnat dst-port=53 in-interface=Swisscable protocol=\
    tcp to-addresses=192.168.1.19 to-ports=53
add action=dst-nat chain=dstnat dst-port=81 in-interface=Telefonica protocol=\
    tcp to-addresses=192.168.1.19 to-ports=12001
add action=dst-nat chain=dstnat dst-port=82 in-interface=Telefonica protocol=\
    tcp to-addresses=192.168.1.19 to-ports=8003
add action=dst-nat chain=dstnat dst-port=555 in-interface=Swisscable \
    protocol=udp to-addresses=192.168.254.1 to-ports=161
add action=dst-nat chain=dstnat dst-port=2000 in-interface=Swisscable \
    protocol=udp to-addresses=192.168.1.200 to-ports=161
add action=dst-nat chain=dstnat dst-port=2000 in-interface=Telefonica \
add action=dst-nat chain=dstnat dst-port=2001 in-interface=Swisscable \
    protocol=udp to-addresses=192.168.1.201 to-ports=161
add action=dst-nat chain=dstnat dst-port=2001 in-interface=Closeness \
add action=dst-nat chain=dstnat dst-port=2001 in-interface=Telefonica \
add action=dst-nat chain=dstnat dst-port=2002 in-interface=Swisscable \
    protocol=udp to-addresses=192.168.1.202 to-ports=161
add action=dst-nat chain=dstnat dst-port=2002 in-interface=Closeness \
add action=dst-nat chain=dstnat dst-port=2002 in-interface=Telefonica \
add action=dst-nat chain=dstnat dst-port=2003 in-interface=Swisscable \
add action=dst-nat chain=dstnat dst-port=2003 in-interface=Closeness \
add action=dst-nat chain=dstnat dst-port=2003 in-interface=Telefonica \
add action=dst-nat chain=dstnat dst-port=2004 in-interface=Swisscable \
    protocol=udp to-addresses=192.168.1.40 to-ports=161
add action=dst-nat chain=dstnat dst-port=2004 in-interface=Closeness \
add action=dst-nat chain=dstnat dst-port=2004 in-interface=Telefonica \
add action=dst-nat chain=dstnat dst-port=2006 in-interface=Swisscable \
    protocol=udp to-addresses=192.168.1.41 to-ports=161
add action=dst-nat chain=dstnat dst-port=2006 in-interface=Closeness \
add action=dst-nat chain=dstnat dst-port=2006 in-interface=Telefonica \
add action=dst-nat chain=dstnat dst-port=5199 in-interface=Swisscable \
    protocol=tcp to-addresses=192.168.1.199 to-ports=80
add action=dst-nat chain=dstnat dst-port=5199 in-interface=Telefonica \
add action=dst-nat chain=dstnat dst-port=5199 in-interface=Closeness \
add action=dst-nat chain=dstnat dst-port=8003 in-interface=Telefonica \
    protocol=tcp to-addresses=192.168.1.19 to-ports=8003
add action=dst-nat chain=dstnat dst-address-type=local dst-port=8882 \
    in-interface=Telefonica protocol=tcp to-addresses=192.168.1.19 to-ports=\
    8882
add action=dst-nat chain=dstnat dst-port=8883 in-interface=Swisscable \
    protocol=tcp to-addresses=192.168.1.19 to-ports=16002
add action=dst-nat chain=dstnat dst-port=8887 in-interface=Swisscable \
    protocol=tcp to-addresses=192.168.1.3 to-ports=443
add action=dst-nat chain=dstnat dst-port=8888 in-interface=Swisscable \
    protocol=tcp to-addresses=192.168.1.10 to-ports=443
add action=dst-nat chain=dstnat dst-port=8889 in-interface=Swisscable \
    protocol=tcp to-ports=22
add action=dst-nat chain=dstnat dst-port=8889 in-interface=Telefonica \
add action=dst-nat chain=dstnat dst-port=8889 in-interface=Closeness \
add action=dst-nat chain=dstnat dst-address-type=local dst-port=8998 \
    in-interface=Swisscable protocol=tcp to-addresses=192.168.1.10 to-ports=\
    22
add action=dst-nat chain=dstnat dst-address-type=local dst-port=8999 \
    in-interface=Swisscable protocol=tcp to-addresses=192.168.1.39 to-ports=\
    22
add action=dst-nat chain=dstnat comment=ps4 disabled=yes dst-port=80 \
    in-interface=Swisscable protocol=tcp to-addresses=192.168.1.6 to-ports=80
add action=dst-nat chain=dstnat dst-address=xxx.xxx.60.46 dst-port=465 \
add action=dst-nat chain=dstnat dst-address=xxx.xxx.60.46 dst-port=443 \
add action=dst-nat chain=dstnat dst-address=xxx.xxx.60.46 dst-port=3478 \
    protocol=udp to-addresses=192.168.1.6
add action=dst-nat chain=dstnat dst-address=xxx.xxx.60.46 dst-port=3479 \
add action=dst-nat chain=dstnat dst-address=xxx.xxx.60.46 dst-port=5223 \
add action=dst-nat chain=dstnat dst-address=xxx.xxx.60.46 dst-port=\
    10070-10080 protocol=tcp to-addresses=192.168.1.6
add action=dst-nat chain=dstnat dst-address=xxx.xxx.60.46 dst-port=3480 \
add action=dst-nat chain=dstnat dst-address=xxx.xxx.60.46 dst-port=3658 \
add action=dst-nat chain=dstnat dst-address=xxx.xxx.60.46 dst-port=10070 \
add action=dst-nat chain=dstnat dst-port=9999 in-interface=Swisscable \
    protocol=tcp to-addresses=192.168.1.47 to-ports=22
/ip ipsec peer
add address=xxx.xxx.177.118/32 dpd-interval=10s enc-algorithm=aes-128 \
    generate-policy=port-override lifetime=10m secret=xxx
add address=xxx.xxx.60.179/32 dpd-interval=10s enc-algorithm=aes-128 \
/ip ipsec policy
add dst-address=192.168.115.0/24 level=unique sa-dst-address=xxx.xxx.177.118 \
    sa-src-address=192.168.222.38 src-address=192.168.1.0/24 tunnel=yes
add dst-address=192.168.10.0/24 level=unique sa-dst-address=xxx.xxx.60.179 \
add check-gateway=ping distance=1 gateway=192.168.3.20 routing-mark=Closeness
add distance=1 dst-address=192.168.222.1/32 gateway=192.168.222.1 \
add check-gateway=ping distance=1 gateway=192.168.2.1 routing-mark=Telefonica
add comment="Damit cs.xxx.xxx auch packetloss von closeness checken kann" \
    distance=1 dst-address=192.168.102.1/32 gateway=192.168.3.20 \
add check-gateway=ping distance=1 gateway=192.168.222.1,192.168.3.1 \
add check-gateway=ping distance=1 gateway=192.168.222.1 routing-mark=\
    Swisscable
add check-gateway=ping comment="default route Swisscable" distance=1 gateway=\
    192.168.222.1
add check-gateway=ping comment="Closeness default route" distance=2 gateway=\
    192.168.3.20
add check-gateway=ping comment="Telefonica default route" distance=3 gateway=\
    192.168.2.1
add check-gateway=ping distance=1 dst-address=xx.xx.120.108/32 gateway=\
    192.168.3.20 scope=10
add comment="Telefonica Check" distance=1 dst-address=84.16.12.250/32 \
    gateway=192.168.2.1
add comment="route Swisscablecheck" distance=1 dst-address=xx.xx.116.0/32 \
    gateway=192.168.222.1 scope=10
add comment="swisscable upstream check" distance=1 dst-address=\
    xx.xx.119.217/32 gateway=192.168.222.1
add comment="hs.xxx.xxx immer \FCber swisscable" distance=1 dst-address=\
    xxx.xxx.177.42/32 gateway=192.168.222.1
add comment="Swisscable Check IP immer \FCber Swisscable" distance=1 \
    dst-address=xxx.xxx.60.1/32 gateway=192.168.222.1
add comment="La Guardia immer \FCber Swisscable" distance=1 dst-address=\
    xxx.xxx.60.179/32 gateway=192.168.222.1
add check-gateway=ping distance=1 dst-address=192.168.102.1/32 gateway=\
    192.168.3.20
/ip service
set telnet port=24
set ftp address=192.168.1.0/24 port=26
set www-ssl disabled=no
/ip upnp
set allow-disable-external-interface=no enabled=yes
/ipv6 address
add address=2001:470:25:27b::2 interface=sit1
/ipv6 firewall filter
add chain=forward in-interface=LAN
/ipv6 nd
set [ find default=yes ] advertise-dns=yes
/ipv6 nd prefix
add autonomous=no interface=LAN
/ipv6 nd prefix default
set preferred-lifetime=4h valid-lifetime=4h
/ipv6 route
add distance=1 dst-address=2000::/3 gateway=2001:470:25:27b::1
set enabled=yes primary-ntp=17.72.148.52 secondary-ntp=79.136.87.162
