CRS226-24G-2S+ with FTC11
Hey Guys,
i need some Help installing an Setup with an CRS226-24G-2S+, an FTC11 and 2 SFP Modules S-85DLC05D.
The Setup is:
  • CRS226 as a Switch for an Management Network
  • Fiber InHouse Cableing (2 Patchpanels) - about 70 Meters Length
  • FTC11 as Copper-Fiber Converter for an Server
My CRS shows Link on the SFP Port, the FTC shows an Link also (but with an Red LED). After checking the Cabeling and some tests with and without AutoNeg there seems to be no way to get any Data through this Connection.
The SFP Port Details on the CRS shows:
Link Length 50um: 550m
Link Length 62um: 270m
SFP Vendor Details
Wavelength: 850nm
RX Power: -7dBm
AutoNeg: done
Rate: 1gbps
Full Duplex: yes
I can see many TX Packets, but no RX Packets.
Does anyone have any Solution for this Problem?
Greetings from Cologne
Sven
May be a silly question, but have you got the cable connected properly?
i.e.
Tx ↔ Rx
Rx ↔ Tx
