CRS226 - basic VLAN docs not working?
I’m trying to follow the documentation for CRS2xx switches (this documentation page) but I can’t get it to work? I’m most likely missing something obvious and simple. :slight_smile:
First of all, `sfp-sfpplus1` is connected to another switch which carries only tagged traffic. One of these VLANs is used for management, just like in the documentation example. In my case management is VLAN 3.
I tried setting up a dhcp-client on mgmt0 after following the documentation sample but didn’t get a lease, so I tried setting up addressing and routing manually, but if I use `/tool/sniffer/quick int` I can only see the following traffic:
[admin@MikroTik] /interface/ethernet/switch> /tool/sniffer/quick
Columns: INTERFACE, TIME, NUM, DIR, SRC-MAC, DST-MAC, VLAN, SRC-ADDRESS, DST-ADDRESS, PROTOCOL, SIZE, CPU
INTERFACE     TIME   NUM  DIR  SRC-MAC            DST-MAC            VLAN  SRC-ADDRESS                                DST-ADDRESS                       PROTOCOL  SIZE  CPU
sfp-sfpplus1  5.364    3  ->   4C:5E:0C:93:12:9A  01:80:C2:00:00:00        802.2       53    0
sfp-sfpplus1  7.368    4  ->   4C:5E:0C:93:12:9A  01:80:C2:00:00:00        802.2       53    0
lo            7.933    5  ->   00:00:00:00:00:00  FF:FF:FF:FF:FF:FF        127.0.0.1:5678 (discovery)                 255.255.255.255:5678 (discovery)  ip:udp     187    0
lo            7.933    6  <-   00:00:00:00:00:00  FF:FF:FF:FF:FF:FF        127.0.0.1:5678 (discovery)                 255.255.255.255:5678 (discovery)  ip:udp     187    0
sfp-sfpplus1  7.936    7  ->   4C:5E:0C:93:12:9A  FF:FF:FF:FF:FF:FF        0.0.0.0:5678 (discovery)                   255.255.255.255:5678 (discovery)  ip:udp     207    0
sfp-sfpplus1  7.937    8  ->   4C:5E:0C:93:12:9A  01:00:0C:CC:CC:CC        802.2      121    0
sfp-sfpplus1  7.945    9  ->   4C:5E:0C:93:12:9A  01:80:C2:00:00:0E        lldp       178    0
mgmt0         7.947   10  ->   4C:5E:0C:93:12:82  33:33:00:00:00:01        fe80::4e5e:cff:fe93:1282:5678 (discovery)  ff02::1:5678 (discovery)          ipv6:udp   220    0
bridge1       7.947   11  ->   4C:5E:0C:93:12:82  33:33:00:00:00:01     3  fe80::4e5e:cff:fe93:1282:5678 (discovery)  ff02::1:5678 (discovery)          ipv6:udp   224    0
sfp-sfpplus1  7.947   12  ->   4C:5E:0C:93:12:82  33:33:00:00:00:01     3  fe80::4e5e:cff:fe93:1282:5678 (discovery)  ff02::1:5678 (discovery)          ipv6:udp   224    0
mgmt0         7.949   13  ->   4C:5E:0C:93:12:82  FF:FF:FF:FF:FF:FF        192.168.0.6:5678 (discovery)               255.255.255.255:5678 (discovery)  ip:udp     200    0
bridge1       7.949   14  ->   4C:5E:0C:93:12:82  FF:FF:FF:FF:FF:FF     3  192.168.0.6:5678 (discovery)               255.255.255.255:5678 (discovery)  ip:udp     204    0
sfp-sfpplus1  7.949   15  ->   4C:5E:0C:93:12:82  FF:FF:FF:FF:FF:FF     3  192.168.0.6:5678 (discovery)               255.255.255.255:5678 (discovery)  ip:udp     204    0
mgmt0         7.967   16  ->   4C:5E:0C:93:12:82  01:00:0C:CC:CC:CC        802.2      123    0
bridge1       7.967   17  ->   4C:5E:0C:93:12:82  01:00:0C:CC:CC:CC     3        802.2      127    0
sfp-sfpplus1  7.967   18  ->   4C:5E:0C:93:12:82  01:00:0C:CC:CC:CC     3        802.2      127    0
mgmt0         7.967   19  ->   4C:5E:0C:93:12:82  01:80:C2:00:00:0E        lldp       170    0
bridge1       7.967   20  ->   4C:5E:0C:93:12:82  01:80:C2:00:00:0E     3        lldp       174    0
sfp-sfpplus1  7.968   21  ->   4C:5E:0C:93:12:82  01:80:C2:00:00:0E     3        lldp       174    0
sfp-sfpplus1  9.372   22  ->   4C:5E:0C:93:12:9A  01:80:C2:00:00:00        802.2       53    0
I couldn’t see any DHCP request reaching my DHCP server either.
My current configuration is based on the documentation example but expanded using ansible, I’ve just removed some VLANs to make it shorter:
add name=bridge1
/interface vlan
add interface=bridge1 name=mgmt0 vlan-id=3
/interface ethernet switch
set drop-if-invalid-or-src-port-not-member-of-vlan-on-ports="ether1,ether2,ether3,ether4,ether5,ether6,ether7,ether8,ether9,ether10,ether11,ether12,ether13,ether14,ether15,ether16,ether17,ether18,eth\
    er19,ether20,ether21,ether22,ether23,ether24,sfp-sfpplus1,sfpplus2"
/port
set 0 name=serial0
add bridge=bridge1 interface=ether6
add bridge=bridge1 interface=sfp-sfpplus1
add bridge=bridge1 interface=sfpplus2
/interface ethernet switch egress-vlan-tag
add tagged-ports=sfpplus2,sfp-sfpplus1 vlan-id=5
add tagged-ports=ether6,sfpplus2,sfp-sfpplus1 vlan-id=37
add tagged-ports=sfpplus2,sfp-sfpplus1 vlan-id=19
add tagged-ports=ether6,sfpplus2,sfp-sfpplus1 vlan-id=41
add tagged-ports=sfpplus2,sfp-sfpplus1 vlan-id=143
add tagged-ports=switch1-cpu,sfpplus2,sfp-sfpplus1 vlan-id=3
add tagged-ports=sfpplus2,sfp-sfpplus1 vlan-id=46
add tagged-ports=sfpplus2,sfp-sfpplus1 vlan-id=28
/interface ethernet switch ingress-vlan-translation
add customer-vid=0 new-customer-vid=3 ports=ether1
add customer-vid=0 new-customer-vid=3 ports=ether2
add customer-vid=0 new-customer-vid=3 ports=ether3
add customer-vid=0 new-customer-vid=3 ports=ether4
add customer-vid=0 new-customer-vid=28 ports=ether5
add ports=sfpplus2,sfp-sfpplus1 vlan-id=5
add ports=sfpplus2,sfp-sfpplus1 vlan-id=37
add ports=sfpplus2,sfp-sfpplus1 vlan-id=19
add ports=sfpplus2,sfp-sfpplus1 vlan-id=41
add ports=sfpplus2,sfp-sfpplus1 vlan-id=143
add ports=switch1-cpu,ether1,ether2,ether3,ether4,ether6,sfpplus2,sfp-sfpplus1 vlan-id=3
add ports=sfpplus2,sfp-sfpplus1 vlan-id=46
add ports=ether5,sfpplus2,sfp-sfpplus1 vlan-id=28
add address=192.168.0.6/24 interface=mgmt0 network=192.168.0.0
add dst-address=0.0.0.0/0 gateway=192.168.0.254
/system note
set show-at-login=no
I’ve started over a few times using `/system reset-configuration no-defaults=yes skip-backup=yes` and I have serial access to the machine.
