CRS226 DHCP + MAC Limitation Help !
I just bought a mikrotik router CRS226-24G-2S+RM and i wanna know if it’s possible to put some restriction to DHCP, by that i mean to allow IPs only for the “whitelisted” MAC addresses.
It’s this possible ? if yes how can i do it ?
PS: be kind, im newbie with mikrotik.
Regards.
I’m a newbie too.
I believe you just set the pool on the dhcp server to static-only and enter all your static leases for the permitted devices.
