CRS226 + v7.3.1 : Vlans and multiple IPs ?
I’m trying to create the following setup with a CRS226, recently upgraded to 7.3.1
On SFP+1 :
  • Trunk with Vlan 2200-2210, 10, 100
On Interface from Ethernet 1 to 10
  • Access with Vlan 2200 to 2210 (one Vlan per port)
    On interface 22 and 24
  • Access with Vlan 10 on interface 22 with an IP address (no default GW)
  • Access with Vlan 100 on interface 24 with an IP address (w/default GW).
I used this documentation https://help.mikrotik.com/docs/pages/viewpage.action?pageId=103841836#CRS1xx/2xxseriesswitchesexamples-PortBasedVLAN and some older devices with a similar setup however running older version from the OS (CRS212 w/6.33.3, 6.28, 6.46 ) and only one IP.
My questions are :
  • does the CRS226 supports multiple IPs for management ?
  • Is there a major difference between 6.33+ version and 7.3.1 that would make this setup fail ? My debug is that I can’t ping any of the IPs I assign to port 22 or 24 either from the interface themselves or thru the trunk. I tried assigning the ips to the vlan interface I created, and can’t really recall all the test I’ve done, I suspect I’m missing something obvious here.
Any pointers ?
Thanks.
Post the config (run /export hide-sensitive file=anynameyouwish, fetch the file, open it in text editor and obfuscate the remaining sensitive data, such as serial number and any passwords), so we can see what exactly is configured.
I have an update on my case :
I tried to put another trunk w/ vlan10 on ether15, and this one works. So I have 2 different IPs on 2 different bridges.
My issue was that I was not able to make this work on SFP+1 using a S-RJ01.
Then I tried with a random 1G SFP LR, and it worked perfectly.
So, I headed to my bin and dumped those 2x SFP S-RJ01 that I tried.
Anyone as Copper SFP that might be supported better ?
Is it known that S-RJ01 are not reliable ?
Cheers.
