CRS305-1G-4S+ port statistics
i just recieved my new CRS305-1G-4S+ (OS = 6,44beta50 ) and installed it within my network.
TIP: for those, who like me, power the device by a PoE Switch, please ensure to separate the 1st Port from the others within the Mikrotik, a Loop is a nice thing..:wink:
=> i just created a “bridge2” and added only port 1 there, the normal “bridge” then contains only the SFP+ ports
OK.. with my first ATTO benchmark i checked the port statistics and found a interesting thing, it might be an bug..
As you can see there the speed is up to 10G (port 4), while the statistics “end” at 6G, also the p/s graph is limitted to 600k.
tested on Windows 10 with FF 61.0.2 and IE
However, on the APP on my smartphone it looks fine..
can someone confirm or correct me in my findings, please ^^
BR
Its a very small visual bug - worth chucking the info to support@mikrotik.com but doesn’t warrant a huge amount of discussion.
