CRS305 bricked?
I got this little device yesterday and wanted to configure all my sfp+ ports to function as trunks. I’m not familiar with Mikrotik stuff at all so i read documentation and whatever i found to learn the way of how to do it with these device. The default config has one bridge for all ports, which i wanted to change by removing 2 sfp+ ports from the default and creating my own, because i don’t want mgmt to work as trunk … after that, the device became unavailable. I tried resetting, netinstall, nothing works.
Are there any other magic tricks to get this device working or do i have to open RMA?
nvm: -r was the parameter not -e
I would try to connect to the Device via Ether1
Else you will need to RESET the Device as instructed in the Manual or use NetInstall
