Please forgive me for I have sinned. I was excited for this so I put it in production with very little testing…
I have a setup with a few VM hosts running about 20 vms. The VM hosts have been plugged into a unmanaged 1gb switch passing traffic just fine.
I decided to play around with some 10g gear so I picked up a mikrotik crs305-1g-4s+ and some 10Gb PCI-E NICs. I settled on 10G SFP+ DAC cables for the closer servers and a chunk of fiber with 10GBASE-SR Module for Mikrotik S+85DLC03D for longer run. I ended up using an additional mikrotik crs305-1g-4s+ on the end of the fiber run so I could have more 10G ports to play with.
At this point all the youtube videos that I’ve seen say that everything should just work.
I run a udp speedtest from the first mikrotik crs305-1g-4s+ (lets call it mikrotik A) to the other mikrotik crs305-1g-4s+ (mikrotik B) across the fiber link and I see about 950Mbps. Here’s my stats for the link on mikrotik A.
/interface ethernet monitor sfp-sfpplus1
status: link-ok
auto-negotiation: done
rate: 10Gbps
full-duplex: yes
tx-flow-control: yes
rx-flow-control: yes
advertising:
link-partner-advertising:
sfp-module-present: yes
sfp-rx-loss: no
sfp-tx-fault: no
sfp-type: SFP-or-SFP+
sfp-connector-type: LC
sfp-link-length-50um: 80m
sfp-link-length-62um: 30m
sfp-vendor-name: Mikrotik
sfp-vendor-part-number: S+85DLC03D
sfp-vendor-revision: A
sfp-vendor-serial: MISSRJ52813
sfp-manufacturing-date: 14-06-01
sfp-wavelength: 850nm
sfp-temperature: 37C
The other issue that I’m having is that mikrotik A doesn’t “contain” the traffic like the unmanaged switch did. I now see all the traffic between the VM hosts cross my main router.
I’d appreciate any help…
