Ordered one of these SFP+ switches/routers to use for a storage 10GBe backend and am having some VERY frustrating problems.
Summary:
Ubiquiti 48 PoE switch
Latest firmware for Mikrotik switch
VLAN 7 assigned to port 48
PoE/Boot/WLAN port (ethernet), set to VLAN 7 and plugged into port 48
In default config I change the IP to auto and set it to listen on WLAN port and renew lease, magically I get an IP on the PoE/Boot Ethernet port for 192.168.7.119.
Go back into interface, System>>Routerboard>> set it to SwOS.
Switch back to my wifi network away from direct and I can access the switch from my home network on that IP.
So far all is gravy.
Reboot the switch and nothing works anymore.
All I want is a dumb GBe switch to hook up a bunch of storage too and after dealing with this thing for hours I’m not really in any better shape. What am I missing here? I’m not changing much in the config and it works fine but once I reboot the switch, it isn’t accessible anymore and I have to reset it and start over. What’s the point if I can’t persist the changes and reboot freely. Any help?
Seed
