I purchased CRS309 with a few tranceivers and cables for homelab. Tried different setups and only DAX works.
- CRS309 - DAX - Intel X520 = works
- CRS309 - Wiitek Mikrotik-compatible RJ45 Transceiver (new) - STP Cat 7 - Wiitek Transceiver - Intel X520 = no link, no carrier
- CRS309 - AIO Transceiver (used) - OM4 Fiber - AIO Transceiver - Intel X520 = no link, no carrier
Intel X520 (options ixgbe allow_unsupported_sfp=1 + EEPRROM patched)
Settings for enp8s0:
Supported ports: [ FIBRE ]
Supported link modes: 10000baseT/Full
Supported pause frame use: Symmetric
Supports auto-negotiation: No
Supported FEC modes: Not reported
Advertised link modes: 10000baseT/Full
Advertised pause frame use: Symmetric
Advertised auto-negotiation: No
Advertised FEC modes: Not reported
Speed: Unknown!
Duplex: Unknown! (255)
Auto-negotiation: off
Port: FIBRE
PHYAD: 0
Transceiver: internal
I have no other 10G equipement to test each component separately.
Q1. Is CRS309 picky about transceivers? Does CRS309 have any vendor lock?
Q2. The wiki (https://wiki.mikrotik.com/wiki/MikroTik_wired_interface_compatibility#S+RJ10) says
Use these modules only in 10G SFP+ ports with auto-negotiation enabled
But my X520 does not support auto-negotiation. Does it mean I cannot use CRS309 + X520 with a cat7 copper cable?
Q3. Can I connect CRS309 Port1 and Port2 (loop?) to test tranceivers and cables?
