Hey Guys,
I’m having some issues with my port configuration. When testing VLAN 501 it works great to a end device but I’m having issues with VLAN 201. Specifically I can’t ping the IP I put on the VLAN 201 interface. Any suggestions on what to do with config?
VLAN 201 is the Mikrotik Management VLAN. It only needs to be bound to SFP4 (Uplink Port).
VLAN 501 is Data which is tagged on SFP4 (Uplink) and untagged on all the rest of the ports.
Version 7.4.1
add ingress-filtering=no name="Main Bridge" vlan-filtering=yes
/interface vlan
add interface="Main Bridge" name=vlan201 vlan-id=201
add bridge="Main Bridge" ingress-filtering=no interface=sfp-sfpplus4
add bridge="Main Bridge" ingress-filtering=no interface=sfp1 pvid=501
add bridge="Main Bridge" ingress-filtering=no interface=sfp2 pvid=501
add bridge="Main Bridge" interface=sfp3 pvid=501
add bridge="Main Bridge" interface=sfp4 pvid=501
add bridge="Main Bridge" interface=sfp5 pvid=501
add bridge="Main Bridge" interface=sfp-sfpplus1 pvid=501
add bridge="Main Bridge" interface=sfp-sfpplus2 pvid=501
add bridge="Main Bridge" interface=sfp-sfpplus3 pvid=501
/interface bridge vlan
add bridge="Main Bridge" tagged=sfp-sfpplus4 untagged=\
sfp1,sfp-sfpplus1,sfp-sfpplus2,sfp-sfpplus3,sfp2,sfp3,sfp4,sfp5 vlan-ids=\
501
add bridge="Main Bridge" tagged=sfp-sfpplus4 vlan-ids=201
add address=172.28.239.16/25 interface=vlan201 network=172.28.239.0
add disabled=no dst-address=0.0.0.0/0 gateway=172.28.239.1
