CRS312-4C+8XG wan to bridge/vlan fasttrack issue
Hi folks, hoping someone can help shed a light on some speed issues.
I have a relatively simple setup, where a machine from a vlan (bridge) runs a speed test to the internet and loads the CPU to 100% on the CRS312, leading to poor performance. Download caps at around 350MBit/s, while internet is provisioned and tested at 1Gbit/s (link is 2.5Gbit/s) (tested when the same machine is connected directly to the modem).
WAN <--(2.5Gbit/s)--> CRS312 <--(10Gbit/s)--> CRS310 <--(2.5Gbit/s)--> desktop machine
Note that I can do full 2.5Gbit/s from that desktop machine to another one connected directly to the CRS312, so the bridge is operating at maximum line speed. It’s when we exit the bridge and enter back that the CPU gets overloaded.
As far as I understand, RouterOS 7.12.1, which I’m running, should be able to hardware offload/fasttrack everything that comes back from the WAN to a vlan machine on the bridge, but it doesn’t look like it’s the case. I assume I made some configuration error so here’s the relevant config:
/interface> print detail
4  R   ;;; Internet
        name="ether1" default-name="ether1" type="ether" mtu=1500 actual-mtu=1500 l2mtu=1584 max-l2mtu=10218 mac-address=78:9A:18:5D:FA:96
        ifname="eth1" ifindex=9 id=2 last-link-up-time=2023-12-17 13:07:34 link-downs=0
13  R   name="DESKTOP" type="vlan" mtu=1500 actual-mtu=1500 l2mtu=1580 mac-address=78:9A:18:5D:FA:9E ifname="vlan18" ifindex=25 id=18
        last-link-up-time=2023-12-17 13:07:26 link-downs=0
18  R   name="bridge" type="bridge" mtu=auto actual-mtu=1500 l2mtu=1584 mac-address=78:9A:18:5D:FA:9E ifname="br0" ifindex=21 id=14
/ip/firewall/filter> print
Flags: X - disabled, I - invalid; D - dynamic
 0  D ;;; special dummy rule to show fasttrack counters
      chain=forward action=passthrough
 1    ;;; Hardware fasttrack for established connections
      chain=forward action=fasttrack-connection hw-offload=yes connection-state=established,related log=no log-prefix=""
 2    ;;; Forward established connections
      chain=forward action=accept connection-state=established,related log=no log-prefix=""
 3    ;;; Accept established connections
      chain=input action=accept connection-state=established,related,untracked log=no log-prefix=""
 4    ;;; Drop invalid packets
      chain=input action=drop connection-state=invalid log=no log-prefix=""
 5    ;;; Drop packets from the Internet
      chain=input action=drop in-interface=ether1 log=no log-prefix=""
/ip/firewall/nat> print
 0    chain=srcnat action=masquerade log=no log-prefix=""
/ip/firewall/mangle> print
      chain=prerouting action=passthrough
 1  D ;;; special dummy rule to show fasttrack counters
 2  D ;;; special dummy rule to show fasttrack counters
      chain=postrouting action=passthrough
/interface/bridge> print
 0 R name="bridge" mtu=auto actual-mtu=1500 l2mtu=1584 arp=enabled arp-timeout=auto mac-address=78:9A:18:5D:FA:9E protocol-mode=rstp fast-forward=yes
     igmp-snooping=no auto-mac=no admin-mac=78:9A:18:5D:FA:9E ageing-time=5m priority=0x8000 max-message-age=20s forward-delay=15s
     transmit-hold-count=6 vlan-filtering=yes ether-type=0x8100 pvid=1 frame-types=admit-only-vlan-tagged ingress-filtering=yes dhcp-snooping=no
/interface/bridge/port> print detail
Flags: X - disabled, I - inactive; D - dynamic; H - hw-offload
 1   H interface=ether3 bridge=bridge priority=0x80 path-cost=10 internal-path-cost=10 edge=auto point-to-point=auto learn=auto horizon=none hw=yes
       auto-isolate=no restricted-role=no restricted-tcn=no pvid=1 frame-types=admit-only-vlan-tagged ingress-filtering=yes unknown-unicast-flood=yes
       unknown-multicast-flood=yes broadcast-flood=yes tag-stacking=no bpdu-guard=no trusted=no multicast-router=temporary-query fast-leave=no
Please let me know if you see anything obvious or if it would be useful to post more configuration details!
After searching for hours, I finally found the answer in the documentation. Specifically:
FW - the feature requires l3-hw-offloading=no for a given switch port. On the switch level, l3-hw-offloading=yes.
So I turned on l3-hw-offloading at the switch level, and turned off l3-hw-offloading at the port level (WAN port), and now I get full speed, with minimal CPU usage. I hope this post helps someone in the future! This was the opposite of the default settings.
Hi, What did you do wrong.
What percentage does the CPU reach?
Where did you insert the WLAN interface? in the Bridge?
Could you help me solve my problem? it’s the same as yours!
