do the combo ports on their STP sockets support the same range of speeds as the main ports - that is, including 2.5 and 5 Gb, or are they only 1/10 Gb?
Thank you.
Thank you.
Independent ethernet ports support 10M/100M/1G/2.5G/5G/10G
Ethernet combo ports 10M/100M/1G/2.5G/5G/10G
SFP combo ports 1G/10G
MGMT/BOOT ethernet port 10M/100M
Thanks a lot for the response.
