CRS312 Issues
Hi. I have currently setup my router.
CRS312-4C+8XG-RM To be exact. I have configured it in quickset and my workstations are not grabbing the correct IP from the router. The workstations actually bypassed the mikrotik and grabbed the ISP router address instead.
DHCP enabled in Mikrotik router mode.
Sounds like you configured / connected it up as a switch. Which CRS’s are anyway.
Post the exported config here and someone will try and assist
jan/02/1970 00:22:48 by RouterOS 6.44.4
software id = 8AUA-YJN6
model = CRS312-4C+8XG
serial number = BF750AF0A772
add admin-mac=74:4D:28:D7:E9:33 auto-mac=no comment=defconf name=bridge
add name=WAN
add name=LAN
/ip hotspot profile
add name=dhcp ranges=192.168.88.3-192.168.88.254
add address-pool=dhcp disabled=no interface=bridge name=dhcp1
add bridge=bridge comment=defconf interface=combo1
add bridge=bridge comment=defconf interface=combo2
add bridge=bridge comment=defconf interface=combo3
add bridge=bridge comment=defconf interface=combo4
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf disabled=yes interface=ether9
add interface=ether9 list=WAN
add interface=bridge list=LAN
add address=192.168.88.1/24 interface=ether1 network=192.168.88.0
/ip dhcp-client
add dhcp-options=hostname,clientid disabled=no interface=ether9
add address=192.168.88.0/24 gateway=192.168.88.1 netmask=24
/system routerboard settings
set boot-os=router-os
For configure your CRS use winbox, quickset have many problems.
I am using winbox to configure. I still cant get around the issue.
I need to set it as a router, then I might be able to solve this issue.
Here is my problem.
My internet connection is 500 down 500 up.
Configured manually on IMac using a CalDigit connect 10gb adapter
1GBps Setting on a 10gbe adapter = 500 down 500 up
2.5GBps Setting on a 10gbe adapter = 500 down 150 up
5GBps = 500 down 100 up
10GBps = 500 down 78 up
Automatic on IMac using CalDigit connect 10gb adapter
Have anyone faced this problem before? Thanks in advance!
The WAN interface (ether9) must not be part of the bridge config, must be totally removed
IP address for LAN should be assigned to bridge interface, not sub/slave interface ether1
I am too having this issue. How do I remove ether9 from the bridge config? I am super new to Mikrotik swtiches and having problem setting this switch as a router instead of just a switch.
In Winbox:
Menu->Bridge->Ports
Select interface to be removed and click on “-” minus sign
In CLI:
/interface bridge port remove [find where interface=“ether9”]
Thanks! So far sorted with internet. But there is one problem
Currently my internet is limited to 300mbps up down.
When I bypass the Mikrotik, I get 800mbps down 600 up. This is my original speed. Any ideas?
Thanks!
It’s a switch, not a router, so it has only very limited routing capabilities:
https://mikrotik.com/product/crs312_4c_8xg_rm#fndtn-testresults
Which means I can never get my full internet speed with this switch?
But when it was on bridge mode, I was getting a good 500 up and down.
If you use it as a router - no, you can’t.
But you will get full internet speed, if you use it as a switch.
And some router that can handle 800/600 connection - as a router.
How can I use it as a switch only? Which means the IP address follows my current router.
Thanks in advance! Sorry I am still learning.
I don’t really understand the question, but I guess yes, you can use your current router for routing, nat, firewall, dhcp server, dns etc.
And CRS will do switching between LAN devices on speeds up to 10Gb/s.
And also between LAN and the router.
Sorry for being unclear. When the Mikrotik is in bridge mode. I don’t get full internet speed. When it’s on router mode. It’s capped at 300 up down.
So basically. I am not getting full internet speeds on the Mikrotik. Local 10GBE is fine for now. So I was thinking if I were to revert it back to a bridge. Can that help? My original internet speed is 800 up down.
When in simple “bridge mode” (all ports in one bridge, no vlans etc.) the bottleneck will be not the CRS but rather your router.
Thanks.
When in bridge mode, its abit funny. If I am running 1GBE I get 800 up down. If I set the network adapter to 10GBE, I get a drop in speed. 130 up down.
I dont have an explanation for this. Did you ever encounter such issues before?
Thanks!
That sounds weird.
Do you switch to fixed rates both on client and the switch?
If both ends are set to auto negotiation, what rate is actually chosen?
If the adapter is set to auto nego, it goes to 10GBE. Until now I am still figuring out this problem.
10GBE local speeds work fine. Just the internet part is driving me crazy.
