CRS317-1G-16S+RM AC/DC
Hey Guys
I want to use the CRS317-1G-16S+RM in a Active Street Cabinet environment (Fibre Access POP, Want to eventually remove the Cisco ASR920) (-48VDC).
What about the “internal voltage” behind the two bulit in AC power supplies? 24VDC, 48VDC?
Is it possible to replace the internal AC power supply, found this https://shop.meconet.de/Stromversorgung/bis-48-Volt/DC-Umruestsatz-von-AC-auf-DC-fuer-MikroTik-CCRs::117098.html
Mikrotik now have a proper telecom PSU for the CCR -
https://mikrotik.com/product/hot_swap__48v_dc_telecom_power_supply_for_ccr1072
I have a feeling it’s 24v, but you’d need to crack one open and check.
I previously asked this exact question and the reply was basically no they aren’t releasing a DC PSU for the CRS317 :frowning:
CCR1072 has a DC PSU IIRC, but very expensive and overkill for what you probably will be using it for
