CRS317-1G-16S+RM reboots endlessly in switch mode (ok on router mode)
I bought 2 devices:
CRS305-1G-4S+IN - 4 SFP port router/switch
CRS317-1G-16S+RM - 16 SFP port router/switch
The 4 port device can work OK changing between
router and switch modes.
The 16 port device works OK as router,
but when changed to switch, it keeps rebooting in endless loop
and cannot be connected to by winbox.
I can press the reset and then power on to default it back
to router mode, and it will work as router.
How can I repair this problem to get switch mode working?
In RouterOS I can get this information:
Model: CR317-1G-16S+
Serial Number:
Firmware Type: dx3230L
Factory Firmware: 6.44.5
Current Firmware: 6.44.5
Upgrade Firmware: 6.44.5
Settings:
Auto Upgrade: not checked
Baud Rate: 115200
Bout Delay: 2
Enter Setup On: any key
Boot Device: nand-if-fail-then-ethernet
Boot OS: RouterOS (which I change to SwOS and reboot causing this problem)
Boot Protocol: bootp
Reformat Hold Button: 00:00:20
Enable jumper reset: checked
Force backup booter: not checked
Silent Boot: not checked
Protected Routerboot: not checked
Thanks.
