You made my day with your suggestion. I love how you described the power led, a laser drill direct to the eye. Anyway it isn’t a problem to me, but I respect the opinion from others.
The proper destination for this is … well, none as no sub-forum is dedicated to hardware-related feature requests. So the best of the wrong destinations is probably an e-mail to support@mikrotik.com.
And I agree with you that those fancy blue LEDs should be banned or at least they should have to automatically change color to red if the ambient light falls below daylight level as blue light affects the sleep cycle. As a non-intrusive workaround until Mikrotik recalls all the units sold so far for retrofitting, an aluminium sticky tape and a pin can be used to reduce the photon flow.
