I’ve got a question related to this device.
Has anyone used this in production environment, if so, how reliable has it been for you?
Can the SFP+ work at 1 GE with SFP transceivers? or are fixed at 10GE?
Have you used it to mirror traffic? have you experienced any delay when working like this?
My potential use case is the following:
Connect 2x10Ge and 1x1Ge FO based connections, and mirror all the incoming traffic (potentially 21 gbps) to another set of ports for analysis in parallel to delivering the frames to the proper end point, as in, I just want to use this device as a “network tap”, hence no routing would be happening here, just switching.
Thank you in advance.
