CRS317 High CPU
Hi everybody!
I have a CRS317 that has high load CPU (Networking proccess).
I’m using it only for switching capability.. When the traffic reaches 1GB or 1.2GB, the CPU go to 100%
I attached the config.
Maybe the configuration is wrong?
Thank you in advance!
Marcos.
last.rsc (5.15 KB)
Hi Marco,
Something in your config is causing it to process packets in software, the CPU has a 1Gb speed bottleneck.
I would start by taking a look at this page:
https://wiki.mikrotik.com/wiki/Manual:CRS3xx_series_switches
Regards, Kevin
You should rewrite your config using new Bridge VLAN features for Hardware Offload.
https://wiki.mikrotik.com/wiki/Manual:Interface/Bridge#Bridge_VLAN_Filtering
Thank you!
I will try with this.
Regards,
Marcos.
Hi!
Now its working fine!
Thanks a lot.
Marcos.
