CRS317 - HW. Offloading only works on a single bridge, is it a bug?
I have found that the HW. offloading works without problems in the first bridge I created.
However, on the second bridge, under the same conditions as the first, there is no way to activate HW.offloading.
Does v6.42.6 on the CRS-317 only allow active Hw. offloading on a single bridge?
Currently yes, HW only on one bridge.
Are you planning to expand it in future versions?
If so, is there an estimated time frame?
make vlans on the bridge to segment your switch, there is no need for multiple bridges
You’re right, thank you!
I’m not sure how to do it.
I need:
untagged bonding1 <----> untagged bonding2
tagged bonding3 vlan151 <------> tagged port1 vlan151
I had them in 2 bridges because I need them to be totally isolated and I’m not sure how to do it, because there is no drop that I can configure between them.
Could it be enough to use “admit only VLAN tagged” on the tagged ports and “admit only VLAN untagged” on the others?
