Crs317 limit bandwidth
Please share your config:
/export file=anynameyoulike
Make sure to remove serial and any other private information (like public IP).
Here it is:
# model = CRS317-1G-16S+
# serial number = xxxxxxxx
add name=SWITCH priority=0x2048
set [ find default-name=ether1 ] disabled=yes
set [ find default-name=sfp-sfpplus1 ] advertise=\
    10M-half,10M-full,100M-half,100M-full,1000M-half,1000M-full,10000M-full \
    comment="IIN-NET 2625G" name="sfp-sfpplus1   |IN" speed=10Gbps
set [ find default-name=sfp-sfpplus2 ] advertise=1000M-full,10000M-full name=\
    "sfp-sfpplus2  CLIENT-1" speed=10Gbps
set [ find default-name=sfp-sfpplus3 ] disabled=yes
set [ find default-name=sfp-sfpplus4 ] name=sfp-sfpplus4-CLIENT-2 \
    rx-flow-control=on tx-flow-control=on
set [ find default-name=sfp-sfpplus5 ] disabled=yes
set [ find default-name=sfp-sfpplus6 ] advertise=\
    name="sfp-sfpplus6-CLIENT-3" speed=10Gbps
set [ find default-name=sfp-sfpplus7 ] auto-negotiation=no disabled=yes \
    speed=10Gbps
set [ find default-name=sfp-sfpplus8 ] disabled=yes
set [ find default-name=sfp-sfpplus9 ] disabled=yes full-duplex=no speed=\
    100Mbps
set [ find default-name=sfp-sfpplus10 ] disabled=yes
set [ find default-name=sfp-sfpplus11 ] disabled=yes
set [ find default-name=sfp-sfpplus12 ] disabled=yes
set [ find default-name=sfp-sfpplus13 ] disabled=yes
set [ find default-name=sfp-sfpplus14 ] disabled=yes
set [ find default-name=sfp-sfpplus15 ] disabled=yes
set [ find default-name=sfp-sfpplus16 ] speed=100Mbps
set 0 limit-unknown-multicasts=yes limit-unknown-unicasts=yes
set 1 egress-rate=630.0Mbps ingress-rate=630.0Mbps limit-unknown-multicasts=\
set 2 limit-unknown-multicasts=yes limit-unknown-unicasts=yes
set 3 egress-rate=690.0Mbps ingress-rate=690.0Mbps limit-unknown-multicasts=\
set 4 limit-unknown-multicasts=yes limit-unknown-unicasts=yes
set 5 egress-rate=485.0Mbps ingress-rate=485.0Mbps limit-unknown-multicasts=\
set 6 limit-unknown-multicasts=yes limit-unknown-unicasts=yes
set 7 limit-unknown-multicasts=yes limit-unknown-unicasts=yes
set 8 limit-unknown-multicasts=yes limit-unknown-unicasts=yes
set 9 limit-unknown-multicasts=yes limit-unknown-unicasts=yes
set 10 limit-unknown-multicasts=yes limit-unknown-unicasts=yes
set 11 limit-unknown-multicasts=yes limit-unknown-unicasts=yes
set 12 limit-unknown-multicasts=yes limit-unknown-unicasts=yes
set 13 limit-unknown-multicasts=yes limit-unknown-unicasts=yes
set 14 limit-unknown-multicasts=yes limit-unknown-unicasts=yes
set 15 egress-rate=820.0Mbps ingress-rate=820.0Mbps limit-unknown-multicasts=\
add name=WAN
add name=LAN
/ip ipsec proposal
set *0 dns-server=8.8.8.8,8.8.4.4
add bridge=SWITCH interface="sfp-sfpplus1   |IN"
add bridge=SWITCH interface=sfp-sfpplus3
add bridge=SWITCH interface=sfp-sfpplus4-CLIENT-1 unknown-multicast-flood=no
add bridge=SWITCH interface="sfp-sfpplus2  CLIENT-2" \
add bridge=SWITCH interface=sfp-sfpplus5
add bridge=SWITCH interface=sfp-sfpplus10
add bridge=SWITCH interface=sfp-sfpplus16 unknown-multicast-flood=no
add bridge=SWITCH interface=sfp-sfpplus8
add bridge=SWITCH interface=sfp-sfpplus7
add bridge=SWITCH interface="sfp-sfpplus6-CLIENT-3" unknown-multicast-flood=\
    no
add interface=ether1 list=LAN
add interface="sfp-sfpplus1   |IN" list=WAN
add interface="sfp-sfpplus2  CLIENT-1" list=LAN
add interface=sfp-sfpplus3 list=LAN
add interface=sfp-sfpplus4-CLIENT-2 list=LAN
add interface=sfp-sfpplus5 list=LAN
add interface="sfp-sfpplus6-CLIENT-3" list=LAN
add interface=sfp-sfpplus7 list=LAN
add interface=sfp-sfpplus8 list=LAN
add interface=sfp-sfpplus9 list=LAN
add interface=sfp-sfpplus10 list=LAN
add interface=sfp-sfpplus11 list=LAN
add interface=sfp-sfpplus12 list=LAN
add interface=sfp-sfpplus13 list=LAN
add interface=sfp-sfpplus14 list=LAN
add interface=sfp-sfpplus15 list=LAN
add interface=sfp-sfpplus16 list=LAN
/interface sstp-server server
set default-profile=default-encryption
add address=XX.XX.XX.XX/28 interface=SWITCH network=XX.XX.XX.XX
set servers=8.8.8.8,8.8.4.4
add distance=1 gateway=xx.xx.xx.xx/28
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www port=80
set ssh disabled=yes
set api disabled=yes
set winbox port=8291
set api-ssl disabled=yes
/system clock
set time-zone-name=Asia/Baghdad
/system identity
set name=xxxxxxx
/system package update
set channel=upgrade
/system routerboard settings
set boot-os=router-os
